Go to Post To me, my mentors are the Father figures. They guide me through each and everything (even if its not robot related), and try to make it as fun as possible. - RoboMadi [more]
Unread 01-02-2011, 16:37
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Joystick POV hat button?
we are using the logitech extreme 3d pro because it has the twist axis. Does anyone know how to program the POV hat buttons? we want to use it to rotate the camera.
Unread 01-02-2011, 18:13
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: Joystick POV hat button?
They should show up as axis (even though they're just momentary switches). They will either give you -1 or 1 (the Joystick class gives you -1..1, right?).
First two axis should be x and y, third will be the throttle, and if I remember correctly from when I was playing around with my 3D Pro (before it broke), the hat axis should be 4 an 5 (or 3 and 4, if the Joystick class starts enumeration at 0).
