Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 01-02-2011, 17:39
ChapFirebirds ChapFirebirds is offline
FRC #3019 (Firebirds)
ChapFirebirds is an unknown quantity at this point
Multiple Solenoid breakouts?
Does anyone have a design in which they are using a pneumatic breakout and a digital breakout for sensor voltage stability?
The question ultimately is, Can you use more than one breakout on the robot?
Can the 24 volts from the pd power two 9472"s with breakouts? Specifically a pneumatic and a sensor breakout.
Thanks!
FIRST Team 3019
Firebird Robotics
Can you handle the heat?
Unread 01-02-2011, 17:47
Re: Multiple Solenoid breakouts?
The 24V rail should only be used with one solenoid breakout. That single breakout can power both sensors and solenoids.
