Go to Post ..this is the first robot we've built that succeeded at everything we wanted it to. It was simple. It was low maintenance. It scored effectively. It had an autonomous that worked. Its look caught attention. And it was finished on schedule. - Donut [more]
Unread 01-02-2011, 20:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 2010 Denso WIN motor specs
I found it elsewhere on this forum. I haven't ordered these myself, so I'm not sure if it is correct. Here is what someone else referenced:
Connector housing - Mouser p/n 829-12129487 - Delphi p/n 12129487
Connector seal - Mouser p/n 829-15300020 - Delphi p/n 15300020
Terminal (14ga) - Mouser p/n 829-12110845 - Delphi p/n 12110845-L
There are several different terminals available, for different wire gauges:
http://connectors.delphi.com/DCSGDMC...=Y&vE xact=0&
2010 Mabuchi Motor Specs.... PhilBot Motors 13 27-01-2010 19:38
Denso motor specs? Mikhail_Pham Motors 3 21-01-2008 07:10
Attaching Denso motor adapter to the motor? Billfred Motors 3 19-02-2007 20:07
Denso motor Lead Gear specs? billbo911 Motors 5 07-02-2006 16:22
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
