Go to Post SELECT YOUR STRATEGY BEFORE YOUR ROBOT DESIGN. - Kims Robot [more]
Unread 01-02-2011, 20:40
Windows 7 Activation Fix
FIRST just published a fix for the Windows 7 activation problem on the KOP Website
Windows 7 Activation Files
I used it earlier at another team build site and it seemed to work fine. You just need to be connected to the Internet.
Unread 01-02-2011, 20:57
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Windows 7 Activation Fix
Mark,
Could you explain what the Activation problem is and what symptoms we would see?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 01-02-2011, 21:02
Everyone who has re-imaged their Classmate should apply this fix.
When most of us re-imaged our Classmates with Windows 7 (the KOP USB image stick), we did not have an activation code to register it with Microsoft as an Authorized copy of the OS.
FIRST gave us a temporary fix with the Classmate_Update.bat to make the activation notification go away for 30 days.
So if you used it you won't have any symptoms for 30 days, then you'll start getting the "Windows not genuine" message again, and the system would stop working, probably in the middle of a match.
Now they've apparently posted the real activation solution that should be permanent and we won't ever have to worry about this ever again.
Of course, we'll really know 30 days from now...
Unread 04-02-2011, 16:03
You can check to see if you've activated properly by going to:
Start->Computer
System Properties
Look at the very bottom and if you still need to activate it will give you the number of days till the temporary license expires.
You can also initiate activation here if it doesn't automatically pop-up the request.
Unread 15-02-2011, 14:18
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
The activation program consistently fails on our classmate. Can anyone just give me the sla number and I'll register it locally with Microsoft?
Thanks!
Steve Miller
Coach 3355
Summit International Preparatory
Arlington, Texas
Unread 04-03-2011, 01:04
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Originally Posted by ConanMidstone View Post
Getting a following message on my computer.....
Windows 7
Build 7600
This copy of Windows is not genuine.....
What to do???
Have you tried the fix Mark posted at the top of this thread?
Unread 16-03-2011, 01:31
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
We got the same DNS error. The short answer is that we kept at the above fix (the KOP one) and it worked after a couple of tries. The long version is below:
It didn't work for us. We got the hex error code 0x8007267c and an error regarding DNS. The 0x8007267c got us to a Microsoft support page that didn't help, we just graduated to error code 0xc004f050. Eventually we called Microsoft Licensing support http://www.microsoft.com/licensing/e...n-centers.aspx. They told us that we needed to talk tech support, who wasn't there at that hour. It sounds like they could have resolved the problem had we called back when whoever was there.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 16-03-2011, 02:02
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
Just a suggestion, when you press start button and go to the search bar and type "slmgr.vbs -rearm", does it give you another 30 days before activation is required again? Or does that not work?
Unread 16-03-2011, 10:53
We recently got permission to use the network at our team's work site. It's okay for simple web browsing, but the firewall's list of blocked sites and protocols is annoying. One of the things it interferes with is software activation, including CAD and LabVIEW and Windows itself. I've had to take both our Classmates home and use my own Internet connection to get them to activate.
Unread 28-01-2014, 12:24
[martinskot] [martinskot] is offline
2013 Driver
FRC #4618 (CN Robotics)
[martinskot] is an unknown quantity at this point
Thank you so much! I was continuously receiving error messages when trying to activate. I typed that into the search bar, restarted, then had no problem when activating upon startup.
Unread 28-02-2015, 19:36
Kegthedids Kegthedids is offline
FRC #5168
Kegthedids is an unknown quantity at this point
This is the actual activation file. I had activated ours but mistaken to delete them afterwards 2015.
