Go to Post ...it takes a very special kind of person to equate bagpipes with harps. - Kevin Sevcik [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 01-02-2011, 21:30
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: CAN Issues
It sounds like #4 isn't getting enabled in Begin.vi, for some reason or another.
Try "enabling" the motor again at the start of Teleop, and see if it helps.
Another thing you can do is check the "power status" on Jaguar #4. If indicates a power reset more than once, then you need to check its power wiring.
-- Marshal Horn
