Go to Post your robot may have a bit of a "pimpwalk" - GMKlenklen [more]
Unread 10-01-2011, 13:07
Chris is me's Avatar
AKA: Pinecone
Re: Banebot Motor Spec Discrepencies
Somewhat related question: Feeding the motor through the 2.7*1 CIM-U-LATOR gearbox gives it a free speed of ~4700 RPM. Is this close enough to the CIM's ~ ~5300 RPM free speed to be useful? I fear that the motor will "fight" the CIMs being 11% slower. Is that a big enough gap that I should be worried?
Unread 10-01-2011, 13:17
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
No, I wouldn't worry. Consider that under load both will be significantly slowed, which means that both will be trying to move your robot or manipulator in the same direction. The only time it really would matter is in the free running state. However, matching them more closely will obviously increase the efficiency of your mechanism.
I've read that comparing free speeds isn't the best way to match motors. Perhaps there is a better way experimentally (put the motor under identical loads and calculate speeds?).
Unread 16-01-2011, 23:57
Tom Line's Avatar
Originally Posted by Jared341 View Post
Thanks for the reply. Will the CIM-U-LATOR gearboxes come with our choice of motor already installed? If not, could you outline the procedure for installing them (trying to gauge if it is something we can do at our main shop or would need sponsor help)?
Thanks sanddrag. I removed my post here so no one sees it and uses incorrect info.
Unread 17-01-2011, 00:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
13,000 RPM top speed at 12V
spec sheet courtesy of BaneBots is attached
Unread 17-01-2011, 08:32
Would you please provide a link to this article.
Unread 01-02-2011, 21:50
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by WallopingDragon View Post
Does anyone know the reduction of the transmissions on these motors, or did I miss them in one of the previous posts?
This thread is about the Banebots motors which do not have a transmission or gearbox provided in the Kit.
