Go to Post I love it when the robot's develop personality quirks. - Mark McLeod [more]
Unread 31-01-2011, 19:49
ElliotCourant's Avatar
ElliotCourant ElliotCourant is offline
Elliot Courant
AKA: Elliot Courant
FRC #3038 (ICE Robotics)
ElliotCourant is an unknown quantity at this point
Accelerometer
So I'm trying to implement the accelerometer, and i get several errors.
RobotDemo(void):
		myRobot(1, 2, 3, 4),	// these must be initialized in the same order
		leftstick(1),		// as they are declared above.
		rightstick(2),    	// as they are declared above.
		gyro(1,1),
		acc(I2C)
and it gives me this
C:/WindRiver/workspace/Final/MyRobot.cpp:34: error: expected primary-expression before ')' token
How do I implement the accelerometer?
"Error, Cannot Find Back-End!" -WindRiver C++ Error
"If you aren't getting any errors while you are programming, then you are doing something wrong." -Elliot Courant
Unread 31-01-2011, 20:17
Elliot Courant
AKA: Elliot Courant
Re: Accelerometer
bump
Unread 31-01-2011, 22:11
Re: Accelerometer
Be patient. It was less than a half hour before your "bump".
Have you looked at the documentation for the ADXL345_I2C class? Is there anything you don't understand about it?
Unread 01-02-2011, 14:42
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Accelerometer
RobotDemo(void):
		gyro(1,1),
		acc(I2C)
Which line is 34? What is I2C? A constant? A macro? Full source code would be helpful.
Unread 01-02-2011, 18:03
Elliot Courant
AKA: Elliot Courant
Re: Accelerometer
line 34 is "acc(I2C)"
ID:	9918 That is a screenshot of just that part.
And yes I have looked at the documentation but it didn't really help me that much. It just told me that it needed a slot and a PID source. But because the accelerometer is connected to the I2C section I can't get it to work.
Unread 01-02-2011, 18:28
Elliot Courant
AKA: Elliot Courant
Re: Accelerometer
Here is the deceleration of "acc"
But it doesn't give me any errors there
Unread 01-02-2011, 21:58
Emily Horsman
Re: Accelerometer
Attachment 9919
Are you using the ADXL345? In which case you need to use the ADXL345_I2C class, not the Accelerometer class.
Again, what is I2C? A macro? A constant?
Unread 01-02-2011, 22:10
Re: Accelerometer
Quite correct.
In the code Elliot posted, I2C is undefined. That's why the compiler choked on it.
Unread 01-02-2011, 22:12
Emily Horsman
Re: Accelerometer
Elliot did not post his entire source code, there could be a constant or preprocessor definition above the class definition.
