Go to Post I can't wait to get to St. Louis!! Oh wait.. I'm already here!! - Team 288 [more]
Unread 02-02-2011, 01:56
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
To build an craw or not, that tis the question.
One thing we are considering is that do we need an claw this year to be able to pick up game pieces from the floor? Since there is the feed slots on the other end of the field we were just planning on driving back to get a new piece. However looking around it seems that most people are building a claw or some sort to pick up game pieces off the ground. What do you guys thing?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-02-2011, 02:01
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: To build an craw or not, that tis the question.
Seems kinda late to make this decision. But generally, no matter what the game piece, whatever the game, the floor will be littered with game pieces. Just a little something to help you make your decisions.
Good luck.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 02-02-2011, 02:08
The feed slot is perfectly fine as a source of tubes.
However, here are a few factors to consider:
*There will be defense, if you're carrying a tube. Defense subjects robots to hard loads and forces. These forces may cause tubes to leave grippers before they are intended to. Design accordingly.
*Driving all the way over to the far end, picking up a tube, and returning takes time. Wouldn't it be great if your feeders could just throw a tube out to the end of your lane and have you pick it up right there?
*You are going to place, you open your claw, and you suddenly use one of a number of 4-letter words. Your tube is on the ground, and you can't pick it up. Now you have to go all the way across the field to get a new one. Ouch.
*Your opponent (or your partner, or you) drops a tube. You would love to get that, but you can't floor load. The best you can do is shove it into one of your protected areas and hope a partner picks it up.
*In qualifying rounds, it's quite possible that you get 3 robots on your alliance that can't floor load. Every dropped tube is fair game for your opponents, particularly if they have a floor loader.
I call those 5 good reasons to at least consider floor loading.
If you don't floor load, then I would suggest making your grip so solid that the tube can't come out, unless you want it to or have placed it solidly on a peg. Plan on a 165-lb robot hitting yours at any random angle at about 15 ft/second (their speed), bumper to bumper, when you're least expecting it. Then pray that Murphy is taking the day off or bugging some other team...
Unread 02-02-2011, 13:31
pfreivald's Avatar
AKA: Patrick Freivald
If my opponents couldn't floor load, I might intentionally drop tubes in their lanes...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2011, 13:39
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
When my team goes to figure out how to play a game, we think about all the functions a robot can have that are pertinent to the game. Then go through and assign priorities ratings and practicality ratings to each strategy. We decided that floor loading was high on our priority list. If you didn't that's fine. Every team has a different set of priorities. I personally think floor loading is important to have, but given how late in the build season it is, I would stick with what you have, and make it as good as possible.
Unread 02-02-2011, 13:46
pfreivald's Avatar
I agree with all of this but the last.
As long as you've got the weight and motors (or pneumatics) for it, I don't see a reason why, at three weeks left, you wouldn't redesign an arm to accommodate a better strategy.
...you have made your robot modular, right?
Team 1551
I write books, too!
Unread 02-02-2011, 13:57
sgreco's Avatar
AKA: Steven Greco
FRC #2079
I suppose I can agree with this. For something as important as picking up from the floor it would probably be worth going back and redisgning.
The point of was getting at is sometimes time is better spent perfecting an old idea rather than rushing through a good idea. A bad idea that's well built is probably better than a poorly built good idea. At this point I guess it's time to evaluate whether it's worth it to redesign.
Unread 02-02-2011, 14:08
Bob Steele's Avatar
AKA: Bob Steele
Be careful of this strategy in respect to the rules updates. Remember the tube is part of your robot and if you cross the lane with it you will get a penalty... you might be able to push a tube in across the floor ... maybe...
Unread 02-02-2011, 14:18
Mk.32's Avatar
AKA: Mark
Since we have a small team we decided to leave a spot to build an arm on the robot then get the base and forklift done the revisit the Arm. Thinking about it it might seem worth it. But to do it we need to design and build it Hm. Decisions decisions ...
Unread 02-02-2011, 14:35
pfreivald's Avatar
I agree completely... But just dropping a tube in front of someone's lane might be enough to cause serious problems for them if they can't floor-load. (One could always drop a tube, then accidentally hit it in a side-ways-like manner... I'm not making any claims toward GP, or rules or anything -- but we've been burned before by what should have been illegal being allowed by the refs, and even more by not understanding what the rules actually were.)
All that aside, my actual point is this: If you can't pick up from the floor, you're not a top-tier robot. Period.
Team 1551
I write books, too!
Unread 02-02-2011, 18:44
vigkvagkv2's Avatar
vigkvagkv2 vigkvagkv2 is offline
Dignitary Communicator
AKA: Raymond Lindberg
FRC #1778 (Chill Out!)
Team Role: Communications
vigkvagkv2 is an unknown quantity at this point
My team is making a feeder robot this year. With the number of robots doing that this year, you might become a hindrance to your team if you don't have at least some minor floor pickup.
Everything is possible. Some things are just harder to do than others.
Unread 04-02-2011, 02:06
Mk.32's Avatar
AKA: Mark
Yeah this did it, we are building an claw for floor pick up B-)
Unread 04-02-2011, 02:42
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
I bet in 2006 people thought the same thing. Then they saw team 25. They went undefeated through 2 regionals, only 2 loses in route to a Newton Division Championship and ended up Championship Finalists. They got game pieces from their human player on the other side of the field and drove the length of the field to score them. No ground pick-up. 3 Banners, 3 Gold Medals and 1 Silver medal. Thats a top-tier robot.
Teams can be "top-tier" if they excel at the strategy they build for. 3 weeks in, if your strategy is human load only, stick with it and make it unstoppable.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 04-02-2011, 07:39
pfreivald's Avatar
Well, if FIRST has taught me anything, it's that there are exceptions to every rule!
...it just seems to me that floor pickup capability is not that difficult to add to a pre-existing grabber assembly, and not having it is very likely to be a bad idea.
Team 1551
I write books, too!
Unread 04-02-2011, 08:21
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
What, no Get Smart references? Not the Craw...the Craw!
Zan Hecht
