Go to Post In theory, we do not need teachers in this world because we have the written word, but in reality, teachers are one of the most valuable resources, if not the most valuable resource, we have. - Natchez [more]
Unread 08-11-2010, 08:14
pbesen pbesen is offline
FTC #3167
pbesen is an unknown quantity at this point
[FTC]: rubber inserts on tank treads
Does anyone know a good way to get the rubber inserts into the tank treads. I have tried dish soap without good results. Pulling them through with pliers wrecks the inserts.
thanks
Unread 08-11-2010, 15:56
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
Re: [FTC]: rubber inserts on tank treads
we used needle nosed pliers and pushed at the same time. a little bit of deformation but nothing that reduced the performance of the treads.
Unread 08-11-2010, 18:35
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I'm not really speaking from experience, but have you tried slightly heating the tread and freezing the inserts, I've heard of this technique being used to install bearings in machinery.
Unread 01-02-2011, 18:25
dcribbs dcribbs is offline
AKA: Dave Cribbs
FTC #5598 (Parish Robotics)
dcribbs has a spectacular aura aboutdcribbs has a spectacular aura about
Our team is thinking about using tank treads. The tank tread kit comes with 200 tank tread chain links, but the rubber inserts come in packs of 50. Do you need to have a rubber insert for every link or do you skip links? 4 packs of rubber inserts is almost as expensive as the original tank tread kit and was just wondering if you would still get good traction if you didn't have a 1 to 1 ratio.
Any feed-back would help.
Thanks!
Dave Cribbs
Coach & Teacher
FTC - Team 5598, 6635, 6795
FRC - Team 3626
Unread 02-02-2011, 10:23
FTC #3167
We used rubber treads on every other chain link. this seems to work fine although the robot vibrates a lot. I would guess every tread would be best but inserting the treads is very annoying.
BTW. We ended up heating the treads under a hot air source (popcorn maker). Once soft, they went in easier.
[FTC]: Tank Treads in PTC ethan_orion FIRST Tech Challenge 7 10-01-2011 03:48
Tank Treads? reversed_rocker General Forum 7 20-04-2009 19:10
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
Rubber Treads Anyone? archiver 2000 10 24-06-2002 00:29
