Go to Post Anything released in a game hint is subject to enough misinterpretation and "nah, they'll never do that" to deflect any possibility of something being actionable. - EricH [more]
Unread 02-02-2011, 10:56
cmass cmass is offline
FRC #1189
cmass is an unknown quantity at this point
Re: How do they know whos minibot it is?
Originally Posted by thefro526 View Post
To comment on what Al suggested, we are planning on putting Numbers on the left and right sides of our mini-bot that are the same approximate dimensions of our bumper numbers. Numbers that large shouldn't be too difficult to fit onto the mini-bot (I'd imagine most teams should be able to fit 4" numbers somewhere) and they'll be clearly visible to both field personnel and scouts in the stands.
ha!
We were planning to put red and blue electrical tape "bumpers" depending on our alliance color and have our numbrs in same contrasting color that our host bot has on it.
weight nazi's say no way! If it doesn't make it go up the pole faster, it is not on the minibot.
we'd have a hard time getting 1 one four inch number on our minibot, even if you cut it up into little pieces and spread it all around the motor casings and battery pack.
Will probably engrave it into the aluminum because that doesn't add weight!
Unread 02-02-2011, 11:01
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally Posted by cmass View Post
ha!
What are the dimensions of your mini bot? I know ours is at least 8" long, 4" wide and 4" deep so we wouldn't really have a problem putting numbers on it.
As far as it adding weight, if you can't spare the weight of two pieces of cardboard with some numbers on them, then you're probably doing it wrong. Also, you're going to want your mini bot to be clearly distinguishable as yours during the match, assuming that you're not planning on deploying it and sitting at the tower for the last ten seconds.
-Dustin Benedict
Unread 02-02-2011, 11:44
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
As for scoring, I doubt it even matters which of the 3 teams on an Alliance had their MINIBOTS climb. Given that HOSTBOTS cannot interfere with an opponent's TOWER during endgame, HOSTBOTS cannot DEPLOY to those towers. And since each alliance has 2 TOWERs in specific locations, it's easy to tell which alliance to award the points to.
Any team who borrows a MINIBOT from another non-FRC team would probably have been mentioned during the registration of that non-FRC team's MINIBOT. Thus, the coopertition points could be awarded via that channel.
As for borrowing MINIBOTs between FRC teams, I suppose we'll be told how to handle that at the Driver's Meetings.
GitHub
Unread 02-02-2011, 13:19
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
If anything, it will subtract weight!
"It's NOT Just A Robot Thing!"
