Go to Post Anyone who makes a minibot that poots out another minibot that blows the wall apart deserves to have it displayed in the Smithsonian. - Koko Ed [more]
Unread 31-01-2011, 19:02
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Ethan Spitz is an unknown quantity at this point
Re: Line Tracking VI. drives in half a circle...?
Ok, let me know what happens there. IF it doesn't work, I would recheck the wiring. And calibration cause that would rule out the programming problem.
www.team3637.com FIRST team 3637's Website: The Daleks
Unread 31-01-2011, 19:20
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
it works; whats the problem with the default code?
Unread 31-01-2011, 19:24
President
Thats a good question . We just erased it and wrote our own code from scratch. I would suggest that since the default code isn't working.
Ethan
Unread 31-01-2011, 19:26
Ethan
are you willing to help us develop?
Unread 31-01-2011, 19:28
President
Sure. Basically you want to create nested case statements for each combination you can get with the light sensors.
How many sensors are you using? I suggest programming 2 and then adding in a 3rd after you finish that.
Unread 01-02-2011, 12:54
ShockWaveBlue's Avatar
ShockWaveBlue ShockWaveBlue is offline
Registered Nerd
AKA: Jason Rausch
FRC #1742 (Shockwave)
ShockWaveBlue is an unknown quantity at this point
The default code wants you yo use the black wire, not the white. You can just invert the signal in the tele op code and I bet it works.
Design it, Build it, Break it, Fix it. Repeat Process.
Shock What ?!?
Unread 01-02-2011, 13:15
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
Possible solution
The thing our team did was decide on a setup for the sensors....
It looks something like this:
After deciding on this setup we came up with a boolean setup that would, based on which lights were coming back true, turn the robot. We also made the sensory aspect of this custom code activate by pressing and holding button one. When this happened, the robot would no longer recieve x-values from the controller but recieve x-values from the code. It still allowed for y-axis values from the contoller.
jRIO 2013 Project
Unread 02-02-2011, 12:17
Programming Mentor
AKA: Mathwizard
I would be more than happy to help you if you would like. I could give you a basic example of what the nested case structure could look like. Shoot me a PM and ill get right on it.
jRIO 2013 Project
Unread 02-02-2011, 18:13
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Thanks For The Help Everybody... when i get this code semi perfected il post it for the teams that needed help just like us... we got it to track the straight line good enough
Unread 05-02-2011, 12:59
The Trooper The Trooper is offline
FRC #2559 (nOrMaLiTy zErO)
The Trooper is an unknown quantity at this point
Hmmm. Try writing code to see if you man say make a wheel speed up when you cover the sensor or it sees the line etc.
Also the sensor should change from green to and orange red light when its on the line. Does yours do that?
Could you please provide a screen shot of your code as to how you would recommend programming the wheels to turn?
Unread 06-02-2011, 19:54
President
It has case statements heavily nested in it so it won't be to much help. Basically we said if both sensors are off the line go straight, if left sensor is on the line make the right wheel spin a little faster till its off. If right is on the line, make the left wheel spin a little faster.
The middle sensor stays on at all times and if all of them end off the line, it knows which sensor saw the line last and turns that way.
Ethan
