Go to Post Calling all grandmas! We need 3000 crocheted ropes for team's! - Jon Stratis [more]
Unread 02-02-2011, 10:30
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: Power distribution question?
just make sure your controllers can get air circulation or you may have issues there.
Unread 02-02-2011, 10:44
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Originally Posted by squirrel View Post
If you could post some pictures of the robot we might be able to suggest something. Also you might be able to make a board with the PD mounted on top, and the victors/spikes/ etc mounted below, and wires go thru holes to feed power to the various parts.
Hmm, kinda like the imagery of that idea
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-02-2011, 11:56
Originally Posted by 384drtysteve101 View Post
What about victors, spikes, the d-link and its power adapter upside down? I would assume the d-link would be fine but im not sure about the other 3 componets.
As with most components, they don't care which way they are mounted. Electrons are not as influenced by gravity when in the presence of battery. The Dlink needs to be mounted up and away from motors and steel so that the radio can handshake with the field. Rules require that the Dlink be visible from the front of the robot by setup crews. The Victors and Jaguars have indicators that you need to see as well as anyone helping you. You really need to consider a lot of other things as well before you really tie yourself into this design. If an inspector can't complete inspection you can't play.
Unread 02-02-2011, 12:11
AKA: Bryant
Another side note. It is dangerous to charge the battery on its side. so make sure you remove it (which you should be doing anyhwho) before charging it.
Unread 02-02-2011, 12:47
384drtysteve101 384drtysteve101 is offline
FRC #0384 (Sparky)
384drtysteve101 has a little shameless behaviour in the past
Sorry not posting any pictures of our robot, because we dont want other teams in the region to know how we are going on our bot, sorry but i can give a small representation of it.
Name:	breif representation.png
Unread 03-02-2011, 07:40
Bryant,
MK says their batteries can be used in any orientation but should not be charged upside down. I recommend that batteries only be charged upright for a variety of other reasons.
