Go to Post Begging, yelling, kicking, and screaming for members of my team to send me updates while I'm at college not doing homework. - Ginger Power [more]
Unread 01-02-2011, 20:55
kevint kevint is offline
Kevin Tesei
AKA: Kevin Tesei
FRC #1323 (Mad Town Robotics)
kevint will become famous soon enough
CRio won't image
Hey I was trying to get the ZomB dashboard to work on our classmate. I'm not sure if it's related but not only is the robot unresponsive, I am also unable to re-image it. I've tried reinstalling the imager from the disk and putting on the updates but it still fails to image it. I've also tried the thing where you try to image it in safe mode and it reformats it but it still won't work. It also gives me different error messages when I try it different times. They are included. It was also suggested that I somehow revert to the factory image and then try again but I was unable to find out how. I'm also unable to connect via ftp but I can ping it. Help?
File Type: txt error.txt (789 Bytes, 15 views)
File Type: txt error2.txt (326 Bytes, 8 views)
File Type: txt error3.txt (285 Bytes, 8 views)
File Type: txt error4.txt (656 Bytes, 6 views)
Unread 01-02-2011, 21:12
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: CRio won't image
Try setting the safe-mode switch to on and then try to do a full wipe and reimaging of the cRIO. The multiple errors you've been getting seem to be erratic (I got them as well when trying to emergency reimage my team's cRIO), so just keep trying.
Maybe someone knows for sure what they're coming from? I can understand what they're saying, but it's still an internal problem somewhere.
Unread 01-02-2011, 21:20
Kevin Tesei
AKA: Kevin Tesei
Nope. Still didn't work. I've tried that before too. Am I suppose to name is something specific? I've tried Crio CRio and cRIO but they didn't work. Is it even relevant?
Unread 01-02-2011, 21:27
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Posting for a programming mentor on our team...
We're having a similar problem with our 2008 cRio. We've discovered that we can't seem to get the CAN bus plugin for the black jag bridge to work. We're using Java as our coding language and if I disable the console port on the cRio to free it up to be used for the CAN bus, the cRio becomes non-responsive including our ability to get at the ftp ports. We can still ping it. No other response though.
If we disconnect the CAN bus and reenable the cRio's console serial port, it seems to act as normal.
Maybe this will help you debug your problem.
We've ordered a 2CAN in hopes that we can work around the problem.
Trying to Help
Unread 01-02-2011, 22:02
Kevin Tesei
AKA: Kevin Tesei
Hmmm. I managed to rule out one of the error messages (something about having a wrong input parameter). You need to name the crio "Crio" or it won't work.
Unread 01-02-2011, 22:09
Kevin Tesei
AKA: Kevin Tesei
OK, I got past another error (I guess it's called Error 60). I had to disable the wireless thing on my laptop. Now the Error that comes up is 15550. I googled the error message and found this: http://digital.ni.com/public.nsf/all...2574BE0059F494 I don't think it's frc related but maybe someone can make sense of it or find some other solution
Unread 01-02-2011, 23:06
Kevin Tesei
AKA: Kevin Tesei
Nvm... I restarted my laptop and it will image now >_< strange.
Unread 02-02-2011, 12:25
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
imaging can be a big task for a cpu, glad it worked for you.. if it happens again i suggest using the no-app switch instead of safe mode.. thats what they had us do last year.. it works much better in my opinion.. once you start imaging it goes into safe mode automatically
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 02-02-2011, 13:36
Keep in mind that the No App switch only keeps the cRIO from starting up LabVIEW programs. A deployed C++ program will run regardless of the state of the switch.
