Re: Non-static edu.wpi.first.wpilibj.SolenoidBase.getAll() in Eclipse FRC plugin
As of writing this, Eclipse has been updated to the newest sdk - which specifically says in release notes that the getAll() function is fixed. NetBeans should be updated shortly as well.
I have a further question on this - we pulled down the latest Eclipse update, and it has broken everything (and still not fixed the missing static). So I'm wondering what the approved procedure (and how you test this before uploading the update to the site).
We point to the WPI Eclipse site (last night - foolishly I had everyone update their laptops at the same time, rather than trying it on one to make sure it worked), and say update, and accept the one update, etc. But then we have all kinds of problems with getting it "installed" again. We usually end up with some combination going to the preferences, changing our team number, which forces some re-compile, and then putting it back. This latest update now runs an FRC build, but when trying to deploy, it complains about missing some version of a zip file, and saying to go to the WPI site and update. Which we do, and it comes back and says you have the latest. I'm not sitting at the lab right now, so I don't have the exact file and message, but I think it was saying it found v25 and wanted v27. Are you supposed to re-create your workspace / project each time? Or is there some other magic set of steps to make this work? And, just to be clear - the latest set of plugin updates is supposed to fix the static get all method? Could you please tell me what version numbers I should see in the Eclipse about installation details listing, so I can make sure we have the right version. Thanks! Stu |
This is based on my review of netbeans, there may be differences in eclipse. Last edited by Joe Ross : 05-02-2011 at 10:12. |
Yes, you need to replace any failing calls to Solenoid.getAll() with Solenoid.getAllFromDefaultModule().
That should have gone into the release notes... |
I did get this going:
(1) The re-image of the CRIO was required. After updating NetBeans to get the new image for the NI tool, it worked fine. (2) The associated Eclipse updated didn't update the sample code for the dashboard, but if you create it in NetBeans, and then copy it to Eclipse, it has the new call correctly done. |
