Go to Post I would like to know the team simply because it seems they could use a hug. - Taylor [more]
Unread 02-02-2011, 15:13
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Encoder Problems
Originally Posted by Triapod View Post
We recently decided to use the encoders and we are having problems with the programming aspect. When we use the motor with encoder example vi, the motor works but the encoder just shows a small number for the distance and nothing for the rate The numbers flash as if they are changing but remain constant.
The encoder wires were soldered to two female-end pwm cables with the brown to black, orange to red, blue to white, and yellow to white.
It sounds like one of your encoder channels is disconnected.
This would result in the value changing rapidly, but not going anywhere.
-- Marshal Horn
Unread 02-02-2011, 15:16
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
Thumbs up Re: Encoder Problems
That's is what one of our mentors suggested it could be...
jRIO 2013 Project
Unread 02-02-2011, 19:24
Triapod Triapod is offline
Triapod is an unknown quantity at this point
Thank you for the responses. We made sure that the encoder was well secured on the gear box. It might be a hardware problem. These were the encoders that we assembled but never got to use last year so the assembly might have been faulty. We will try again with the encoders from this year and see how it goes.
Unread 03-02-2011, 10:51
Jim.D Jim.D is offline
FTC #1983
Jim.D is an unknown quantity at this point
You can test the encoders using the PSOC I.O. board. If you remove the plastic head from the PWM cables the pine can be connected directly to the PSOC pins as follows.
Orange = VDDIO
Blue = P6_0
Brown = Ground
Yellow = P6_2
Configure the pins as inputs floating. Start the driver station and turn the motor on or spin the encoder by hand. The values should display on the drives station lower right corner.
To install the encoders you should use tools from US Digital or make your own.
The tools ensure that the encoder is centered correctly around the shaft and set the disk to sensor distance. The centering tool is just a small alum collar that fist over the shaft and into the hole of the encoder PCB. The disk insertion tool is a flat plastic disk that presses the disk in slightlt farther than tha cover tabs (approx .05 in farther). The side of the disk that looks like the surface of a CD goes toward the sensor PCB.
