Go to Post Now, what we really need is a big spotlight in the sky that shoots out the letters "CD" so Brandon knows to come running to the server cave ... - mtrawls [more]
Unread 29-01-2011, 10:30
Shrubadub's Avatar
Shrubadub Shrubadub is offline
Shrubadub
FRC #2656 (Quasics)
Shrubadub is an unknown quantity at this point
Testing Joystick
How do you test the joystick in labview without depolying the code to the cRio.
Unread 29-01-2011, 14:28
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Testing Joystick
You can run the code from the robot main vi and then probe the teleop vi while its running. But that deploys your code. There is example code to get joystick values but it wont have the names you need.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 30-01-2011, 10:59
It's possible to write a LabVIEW program that runs on the PC and reads the joystick. But if all you want to do is make sure a joystick is doing what you want, use the Windows Game Controllers control panel.
Unread 02-02-2011, 15:16
Shrubadub's Avatar
Shrubadub
FRC #2656 (Quasics)
Where is that.
Unread 02-02-2011, 15:20
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
Lightbulb Re: Testing Joystick
Originally Posted by Doc Awsume View Post
Where is that.
Goto start;
settings;
control panel;
printers and other hardware;
game controllers;
Add game controller;
finally, when you are dun, it will allow you to do testing/calibration like thing and you can test controllers that way.
jRIO 2013 Project
Unread 02-02-2011, 15:21
Shrubadub's Avatar
Shrubadub
FRC #2656 (Quasics)
Never mind found it.
Unread 02-02-2011, 15:26
Programming Mentor
AKA: Mathwizard
k
Good luck
see you at St. Louis
jRIO 2013 Project
