Re: Windows 7 Starter
You can use any mini-book or laptop for competition. It doesn't have to be from FIRST.
You only need to:
I don't have any experience with Windows 7 Starter, but someone here can probably help if you tell us the steps you took, and give us the first couple of error messages you got. Nothing wrong with switching to XP as long as you have an extra license around. You will have to locate the matching hardware drivers for that model minibook for a different OS to work properly. Last edited by Mark McLeod : 02-02-2011 at 16:26. |
I would not suggest using Windows 7 Starter. We had trouble with it, and that is the reason we put Windows 7 Pro on the classmates.
If you are just using the PC for the driver station win 7 starter is fine. There is a fix for the install errors on the NI website. Google - installing NI on windows 7 starter. It is an easy fix , small edit to the setup.ini files. If you are installing a package that will install several apps at once you have to edit sevearal .ini files not just the first one.
Now I ve solved the installation problem but I cant direct Driver Station to the Driver account I ve created.
Now I am thinking of to set up XP. Thanks for your help. |
I dealt with installation issues on Windows 7 Starter
with the instructions on http://digital.ni.com/public.nsf/all...25768F0000B260 but the problem is I cant direct driver station into a user. I have followed the steps on http://www.chiefdelphi.com/forums/sh...ad.php?t=89340 But I dont still have the driver station in a separate account. How can I have a seperate driver station account on windows 7 starter? Can I keep the classmate with me after we ship the robot and just set the trial version of XP on my classmate when 20 days left to the competition? This seems to be the only way for me after I ve learned that license costs over 50 dolars. |
