Go to Post Team 233 cannot wait for the Florida Regional, but they have to because they have to build a robot or something first. . . - IbleedPink233 [more]
Unread 02-02-2011, 17:53
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Mini Bot Battery Pack
I was using my battery pack for the mini bot early today, but now, it's not working at all. When I plug it into the charger, no lights light up indicating whether or not it is charging. do you know what could be wrong? Thanks for the help.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 02-02-2011, 18:00
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Mini Bot Battery Pack
Check the inline fuse. There is a little cap that you can remove between the battery and the connector. Inside will be a fuse that is most likely blown.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 02-02-2011, 18:02
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
How do I check the fuse? I mean, I see it, but what am I looking for that would be wrong with it. If it is burnt, do I have to get a new one, or can I bypass it? Thanks for the help
Unread 02-02-2011, 18:25
pfreivald's Avatar
AKA: Patrick Freivald
New fuses are available at any auto parts store for really cheap. I highly suggest you use them, instead of bypassing them!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2011, 19:17
If all is well, a fuse has a direct connection from one terminal to the other. An ohmmeter will read approximately zero resistance. If the fuse has blown, it will have no continuity between the terminals, and an ohmmeter will read an open circuit.
Unread 02-02-2011, 19:35
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
It seems to be in there pretty tight. Do you know if I am just supposed to pull on it hard enough till it comes out?
Unread 02-02-2011, 19:40
pfreivald's Avatar
You should just be able to pull on it hard enough so that it comes out, yes.
Team 1551
I write books, too!
Unread 02-02-2011, 19:44
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
It's in there pretty tight. Pliers help. Don't be afraid of it - what are you gonna do, break an already blown fuse?
Hi!
