Go to Post It's not about going for any of the awards. Awards are to recognize what you are doing for First, your team, and the community. - SaraBailey [more]
Unread 02-02-2011, 15:53
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
black jags not showing a solid yellow light
Last night our programers got a base code loded on the crio and they tried to move the moders but the new back jags are not showing any indication lights so I was wondring if they could be burnt out. I think someone might have cross wired the electrical componets and turned on the robot without having the wiring dubble checked any sugestions. Finaly we have tried all the pdm slots on the sidecar
Unread 02-02-2011, 16:16
Re: black jags not showing a solid yellow light
With power added, but no pwm cable plugged in the jaguars should blink yellow.
If they are not blinking yellow then double check the power input with a multi-meter.
If the input power is ~12v, but they do not blink then they are probably broken.
There is an RMA process available for broken Black Jaguars.
Unread 02-02-2011, 16:37
Ok thanks
Unread 02-02-2011, 16:45
wjr1965 wjr1965 is offline
FRC #0862
wjr1965 is an unknown quantity at this point
There are some other posts where teams are reporting issues with black jags that are not working. Any possiblity that there is a production issue?
Unread 02-02-2011, 18:11
Originally Posted by wjr1965 View Post
There are some other posts where teams are reporting issues with black jags that are not working. Any possibility that there is a production issue?
Extremely unlikely.
Take this as an engineering problem and run some numbers.
5,000 Black Jaguars were shipped to teams in the KOP.
More have been purchased through Digikey.
Production runs do have a standard error rate, probably less than 1%, and quality control would pick up on that.
That would mean ~50 Black Jags that might normally be expected to have problems. That would mean ~ 20-25 teams would normally be protesting that their jags aren't working.
So far we've heard only a very few teams out of 2077 complain.
We've seen nowhere near even the NORMAL number of complaints you'd expect with a less than 1% production error rate.
Luminary Micro published an error report after 2009 based on the number of units returned to them that you can checkout. The vast majority of the failures were due to usage, not out-of-the-box bad Jags. There were a few out-of-the-box bad Jags though, so don't be surprised if perfection isn't achieved.
Unread 02-02-2011, 18:20
No its not a bad jag its probobly fired because I as team captien trusted freshmen and sophmores to put back with back and red with red lol
Unread 02-02-2011, 18:42
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Will reversing the polarity fry a Jag?
Unread 02-02-2011, 18:47
Yes.
Unread 02-02-2011, 19:28
wilsonmw04's Avatar
Coach
Originally Posted by Mark McLeod View Post
Yes.
Well that's a downer...
Unread 02-02-2011, 22:35
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
That's funny, our electronics this team is all-but-one freshmen and softmores, and last year a class of juniors and seniors wired a test robot and they fried one.
Do all of the black jaguars not work? It's unlikely that every one is wired backwards, so it might be some other issue.
Unread 03-02-2011, 00:33
Yes bolth jags are broken so lession learned don't let frshmen do things without minor suppervsion
