Go to Post Mentoring is HARD. - Akash Rastogi [more]
Unread 02-02-2011, 18:18
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Switching To Break via Software
is this possible?
Unread 02-02-2011, 18:48
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Re: Switching To Break via Software
Do you mean switching to break from coast such as the victors?
Unread 02-02-2011, 18:49
We've had several times that we've had software break the robot, however, those weren't planned. I'm not sure why you'd purposely program a break mode in the software. Some suggestions are to drive a forklift past it's full extension, drive an arm into the ground, drive full speed into a wall, rotate your swerve drive modules too many times, etc.
To cause a speed controller to switch between brake mode and coast, you can connect one of the digital outputs on the digital side car to the middle pin of the brake/coast header.
Unread 04-02-2011, 13:40
Back after 4 years off
FRC #5279
Only connect the center pin, don't conect the +/- on the break/coast header to anything on the side car. It is also possible to switch between Break and Coast in software using CAN without the additional digital output.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
