pic: 72 lbs so far.
Re: pic: 72 lbs so far.
Looks great!, I find it interesting that your team has gone with belt drive, don't see that too often. Best of luck this season!!!!!
How many air storage tanks do you plan to use? What's the ratio between stored air and cylinder volume?
I like the look of those pneumatic cylinders attached to that interesting looking mechanism. Wished you went to West Michigan again so I could see that robot in person.
Are those 1.5 inch pistons? If so, I think you have way overkill and a smaller piston would lift a lot quicker. Otherwise, looks like a great bot. Wish I had thought of a pneumatic lifter. I like the roller guides on the back.
Bruce |
Do i see a piston driving a piston driving a piston x2? You're going to need so many storage tanks...
#7
Three stacked cylinders, just the kind of pneumatics I love. You can achieve 9 different levels of lift.
You could lift 200lbs with that setup. The good thing is they can run them at reduced pressure and still have more than enough lift. Also if the long cylinders are only used for something like the occasional floor pickup, the air can be stretched even further. I would be more inclined to put the big cylinder on the bottom. |
#8
If Joe had his way there would be even more!!! **** said as I walk away shaking my head!!**** I will admit when I have watched it in motion it flys!!
#9
Just one more thought, you might want to get one of the newer compressors that move 20% more air and have about 1/2 the weight of the old ones. We bought one last week (still waiting for delivery) the model is the viair 090c, here is a link to the only place that sells it that has decent information: http://www.suspensionconnection.com/...con/00090.html
#10
#12
1 Inch cylinders would have worked but the lift was sticking randomly and I wanted to make sure that it would not stick durring competition. Start position is floor pick up and bottom row delivery, the 4 in cylider gives us human delivery, the 4 plus the 8 gives us the center row, and 4 + 8 + 12 gives us the top row with the push of the button. I will use as many tanks as I gan get. Too bad I don't have a few of the new tanks.
#13
I'm willing to bet that the wheels sticking out of the frame on pistons are to line up to the base of the tower before minibot deployment. Very Cool.
#14
What are the Vex wheels for?
#15
Looks like a centering device to align the robot with the tower.
