Go to Post The version that finished nationals was about 50% aluminum and 50% the original PVC and we never had any member break. (structural member, not team member). - Gary Dillard [more]
Unread 02-02-2011, 11:34
JohnFogarty's Avatar
AKA: @doctorfogarty
[FTC]: DC MotorEncoder Code
So in the instance of having servos, those servos have set positions you can send them to. What I want to do is tell a motor to go to specific encoder positions in robotC. I haven't the slightest clue how to begin doing that. My goal is to push a button and have an arm powered by a motor go to a certain position and stop or keep a low level of power to keep it locked in that position until the button isn't pressed.
Thank You.
John Fogarty
John Fogarty
Unread 02-02-2011, 19:15
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
Re: [FTC]: DC MotorEncoder Code
Here's one way to do it:
Have the motor move back until it hits a touch sensor. Set the input from the encoder as the zero position (store it in a variable) and move the motor forward to the encoder position you want, plus the zero value.
We did this to align a dispenser tread on our old robot. If it doesn't rotate all the way around, you may not have to do this.
SAY-WATT.ORG
Unread 02-02-2011, 21:43
AKA: Nathan
Oh, actually, you could just reset the encoder using the software when it hits the touch sensor. Sorry, I'm a hardware guy. I was unsure about my last post, so I read our team's own tutorial on using them.
http://say-watt.org/wp2/archives/391
SAY-WATT.ORG
Unread 04-02-2011, 02:42
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
nMotorEncoder[motorA] = 0;
wait1Msec(50);
nMotorEncoderTarget[motorA] = x;    <- set this to the number of rotations the Motor Encoder needs to rotate
motor[motorA] = 100;
while ((nMotorRunState[leftMotor] != runStateIdle))
    EndTimeSlice();
  return;
This can only be used if you have a shaft encoder attached to the motor you want to use. Good luck.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 04-02-2011, 14:54
clwillingham clwillingham is offline
AKA: Chris 1.0
FTC #2845 (Team Duct Tape)
clwillingham is an unknown quantity at this point
another way thats a bit more direct but probably a little bit less reliable in terms of skidding:
motor[FL] = power;
motor[FR] = power;
motor[BL] = power;
motor[BR] = power;
while(nMotorEncoder[FL] < units){}
Stop(); // we wrote this function to set every motor to 0.
please note that this code is for a four wheel drive robot.
