Go to Post One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. - Dave Scheck [more]
Unread 02-02-2011, 19:17
Re: Mini Bot Battery Pack
Originally Posted by excel2474 View Post
How do I check the fuse? I mean, I see it, but what am I looking for that would be wrong with it.
If all is well, a fuse has a direct connection from one terminal to the other. An ohmmeter will read approximately zero resistance. If the fuse has blown, it will have no continuity between the terminals, and an ohmmeter will read an open circuit.
Unread 02-02-2011, 19:35
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
It seems to be in there pretty tight. Do you know if I am just supposed to pull on it hard enough till it comes out?
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 02-02-2011, 19:40
pfreivald's Avatar
AKA: Patrick Freivald
You should just be able to pull on it hard enough so that it comes out, yes.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2011, 19:44
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
It's in there pretty tight. Pliers help. Don't be afraid of it - what are you gonna do, break an already blown fuse?
Hi!
