Go to Post As JFK said we did not do this because it was easy, we did it because it was hard. - Glenn [more]
Unread 02-02-2011, 19:30
ebarker's Avatar
ebarker ebarker is online now
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Deploying code in Labview, WindRiver, and Java
So we have three parallel projects we wanted to test out.
We formatted the cRio for Labview, deployed code, and it worked.
Then we formatted the cRio for Java, and deployed code. Three green lights on the driver station, but NO response from the joysticks. The robot sits fat dumb and unresponsive, even though we have our three green lights on the DS.
Then we formatted the cRio for C++, and deployed code. Two green lights on the driver station, the red light was on 'no code'. WindRiver sits there forever saying 'deploying' in the lower right hand corner of the screen.
We are clueless as to what the issues are.
Any suggestions ????
EDIT: a) task 'A' - convince ourselves we truly reformatted the cRio
b) task 'B' - make sure we understand what our wired and wireless interfaces on the development pc looks like
Ed Barker
Unread 02-02-2011, 21:39
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Re: Deploying code in Labview, WindRiver, and Java
For Java, the joysticks not working sounds like a code issue. For C++, it sounds like WindRiver wasn't set up properly to connect/download code to the cRIO.
What steps have you taken for both. Can you post the code?
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 02-02-2011, 21:43
zbanks zbanks is offline
AKA: Zach Banks
FRC #0529 (Mansfield Hornets)
zbanks is an unknown quantity at this point
Send a message via AIM to zbanks
You also may need to reconfigure the cRIO each time you switch languages using the software used to reflash the firmware. (You do not need to reformat the cRIO, however, I don't think)
EDIT: My mistake, I misread your post. Ignore this :-)
Unread 02-02-2011, 22:00
ebarker's Avatar
AKA: Ed Barker
Thinking back over the day there may have been an issue with the pc getting confused with the IP address. Both interfaces may have been configured to see the same network.
Re: Java - In Labview you specify that a PWM is associated with a particular module in slot 4 or slot 6. How / where is that done in Java ?
The code was the stock example projects.
Ed Barker
Unread 02-02-2011, 22:09
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
source code would be helpful
and would you require individual PWMs for? In most cases, the electronics have their own classes and all you'd need to specify are the channels.
UPDATE
and make sure you do what zbanks said, format the cRIO to the language you are using
Unread 02-02-2011, 22:41
ebarker's Avatar
AKA: Ed Barker
To answer the question - "how are the 'slots' assigned in Java and C++"
The answer is on page 22 of this document: http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
The source is the default SimpleTemplate in the examples folder.
Ed Barker
