Go to Post If a suspicious distrustful atmosphere is created, then a suspicious distrustful reaction will occur. - JaneYoung [more]
Unread 02-02-2011, 19:54
allie2660 allie2660 is offline
FRC #2660
allie2660 is an unknown quantity at this point
Dashboard Programing
At the moment i am using one of my fellow team members account to post this because my account has problems letting me activate my account. My true problem lies in C++. i was wondering how we would code sensors to show up on our dashboard. i haven't found any posts that give me an answer. and we cant figure it out.
Unread 02-02-2011, 21:34
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Dashboard Programing
that depends on the dashboad, more detail will be nice.
Watchdog.Kill();
Unread 02-02-2011, 22:03
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Your best bet would be to look into ZomB or SmartDashboard (both are on firstforge)
Unread 02-02-2011, 22:30
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
SmartDashboard is actually already integrated into WPIlib by default, so if you just download the client (or my teammate's launcher), you can get started using it with minimal changes to your code.
GSR Dean's List Finalist 2011
Unread 03-02-2011, 09:51
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
While investigating other Dashboard options is a great learning experience, you probably just went "but I just want to use the regular dashboard, shouldn't there be a function to send the proper data?"
If you look at the Dashboard Data Sender example project, it has everything you need. The LabVIEW Dashboard accepts a cluster of data which you can create quite easily (again, see Dashboard Data Sender example).
