Go to Post When twenty people tell you your hair is on fire, you don't need to look into a mirror to find out they're right. - IndySam [more]
Unread 02-02-2011, 20:46
ShadowWing's Avatar
ShadowWing ShadowWing is offline
FRC #3501
ShadowWing is an unknown quantity at this point
Solenoid Fittings?
We want to use the festo double solenoid valve that came in the kit, but we're not sure how to hook it up. The manual suggests that the tube needs to be pushed in, but there are threads, which suggest fittings are required. What fittings, if any, do we need, and where can we find them?
Thanks for any help.
Unread 02-02-2011, 20:49
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Solenoid Fittings?
The fittings should have come in the same bag as the solenoid along with the wires to hook it up.
Unread 02-02-2011, 20:51
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
yes the solenoid fitting were included in the bag, there should have been 3 fittings, and 2 wires
Unread 02-02-2011, 23:55
KenTiffan KenTiffan is offline
FRC #3711
KenTiffan is an unknown quantity at this point
I am member of a rookie team and brand new to Chief Delphi. I am not sure how to pose a question. Our team also plans to use a solenoid, but we have lost the instructions on how to hook it up. For the rectangular Festo with 5 ports (2,4 on one side; 1,3,5 on the other) Which is the inlet port, and which two are the outlet ports that go to the cylinder? Do we just plug the two ports we are not using? Also, were there supposed to be fittings to connect the tubing to the Festo? Is so, we must have lost those too.
Unread 03-02-2011, 02:58
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
I believe 2 and 4 are the outputs to the piston, 3 is the input from the storage tanks and 1/5 are the exhaust ports.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 03-02-2011, 07:28
IndySam's Avatar
The top has two ports 4 and 2. These are the ports that go to the cylinder.
The bottom has 3 ports 5, 1 and 3. Port 1 is the inlet air, 5 and 3 are the exhaust ports for the air exiting the cylinder.
Unread 03-02-2011, 08:20
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Don't plug the other ports, those are the exhaust ports and you want to plug these about as much as you would want to plug your car's exhaust (which I strongly advise against).
