Go to Post Not every team can start 200 teams in Canada or Hawaii because they are located in relatively dense region of teams already. This doesn't mean they can't impact their local and surrounding areas. This is where you have to be creative. - tim-tim [more]
Unread 02-02-2011, 21:03
Lawlhwut Lawlhwut is offline
None #2853
Lawlhwut is an unknown quantity at this point
Autonomous Not Working
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	// Declare Motors
	RobotDrive myRobot;
	Victor LeftDrive;
	Jaguar RightDrive;
	Jaguar Lift;
	Jaguar Claw;
	// Declare Joysticks
	Joystick LeftStick;
	Joystick RightStick;
	// Declare Sensors
	Encoder LeftEncoder, RightEncoder;
	Gyro gyro1;
	static const float Kp = 0.03;
public:
	RobotDemo(void):
		// Set Channels
		myRobot(1,2),
		LeftDrive(1),
		RightDrive(2),
		Lift(5),
		Claw(4),
		LeftStick(1),
		RightStick(2),
		LeftEncoder(3,4,true),
		RightEncoder(5, 6, true),
		gyro1(7)
			// Set Motor Expiration
			LeftDrive.SetExpiration(0.005);
			RightDrive.SetExpiration(0.005);
			Lift.SetExpiration(0.005);
			Claw.SetExpiration(0.005);
			// Set Encoder Displacement Values
			LeftEncoder.SetDistancePerPulse(0.26333);
			RightEncoder.SetDistancePerPulse(0.26333);
	void Autonomous(void)
		//Delcare variables
		int AutoStep = 1;
		// Start sensors
		LeftEncoder.Start();
		RightEncoder.Start();
		gyro1.Reset();
		// Run while in autonomous mode
        while(IsAutonomous())
        	// Return sensor values for tracking
        	float leftdistance = LeftEncoder.GetDistance();
        	float rightdistance = RightEncoder.GetDistance();
        	float angle = gyro1.GetAngle();
        	// Update LCD with new data
        	DriverStationLCD *screen = DriverStationLCD::GetInstance();
        	screen->PrintfLine(DriverStationLCD::kUser_Line1,"Left Motor",LeftDrive.Get());
        	screen->PrintfLine(DriverStationLCD::kUser_Line2,"Right Motor",RightDrive.Get());
        	screen->PrintfLine(DriverStationLCD::kUser_Line3,"Direction",gyro1.GetAngle());
        	screen->UpdateLCD();
			switch(AutoStep)
				case 1:
					// Move forward to set position
					myRobot.Drive(1.0, -angle / Kp);
					Wait(0.005);
					// Stop if distance is reached
					if(leftdistance >= 4953 || rightdistance >= 4953)
						LeftDrive.Set(0);
						RightDrive.Set(0);
						AutoStep = 2;
					break;
				case 2:
					// Drop tube
					Claw.Set(1.0);
					Wait(1.0);
					Claw.Set(0);
					AutoStep = 3;
					break;
				case 3:
					// Adjust for gameplay
					LeftDrive.Set(-0.5);
					RightDrive.Set(-0.5);
					Wait(1.0);
					while(gyro1.GetAngle() > -180 || gyro1.GetAngle() < 180)
						LeftDrive.Set(-0.25);
						RightDrive.Set(0.25);
						Lift.Set(-1.0);
						Wait(0.1);
					break;
	void OperatorControl(void)
		// Reset motors for teleoperator
		LeftDrive.Set(0);
		RightDrive.Set(0);
		Lift.Set(0);
		Claw.Set(0);
		gyro1.Reset();
		// Run while in operator control mode
		while(IsOperatorControl())
			// Get Drive
			float lefty = (LeftStick.GetY());
			float righty = (RightStick.GetY());
			// Desensitize joysticks
			lefty = ((lefty/128)*(lefty/128));
			righty = ((righty/128)*(righty/128));
			// Set Drive
			LeftDrive.Set(lefty);
			RightDrive.Set(righty);
			// Claw Control
			if(RightStick.GetRawButton(2))
					Claw.Set(1.0);
			else
				if(RightStick.GetRawButton(3))
					Claw.Set(-1.0);
				else
					Claw.Set(0.0);
			// Lift Control
			if(LeftStick.GetRawButton(2))
				Lift.Set(1.0);
			else
				if(LeftStick.GetRawButton(3))
					Lift.Set(-1.0);
				else
					Lift.Set(0.0);
			screen->PrintfLine(DriverStationLCD::kUser_Line1,"Left Motor:",LeftDrive.Get());
			screen->PrintfLine(DriverStationLCD::kUser_Line2,"Right Motor:",RightDrive.Get());
START_ROBOT_CLASS(RobotDemo);
Builds flawlessly, but when we try to run it on our prototype robot, the communication is lost and the robot acts funky.
Solutions?
Unread 02-02-2011, 21:54
None #2853
Re: Autonomous Not Working
Addition:
Nothing is wrong with the robot. We tested other programs and it worked perfectly fine.
Unread 12-02-2011, 20:34
PatrickS's Avatar
PatrickS PatrickS is offline
I get my code from /dev/null
FRC #1742 (Shockwave)
PatrickS is an unknown quantity at this point
This sounds more like a hardware problem. Code normally does not affect communication.
Unread 12-02-2011, 21:12
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
I notice you are setting the expiration time for your motor controllers to 5ms. Any reason to use this instead of the default time of 100ms? Otherwise just comment portions out till you find out what is killing you.
Unread 12-02-2011, 23:14
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
Perhaps I was burned by it too much last year, but isn't the watchdog active by default? It will not get fed with the calls to Wait().
Michael Andrews
Team #281 Programming Mentor
