Go to Post "John V-Neun - The Thing / Ken Patton - Mr. Fantastic" I don't think a better description of these two people have ever been posted on ChiefDelphi. - Amanda Morrison [more]
Unread 02-02-2011, 18:09
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Window motor to toughbox?
We need some sort of motor/gearing system to lift our arm. Today we tried the fisher price with the gearbox, and it worked wonderfully except it doesn't stay put when you take the power off it, as in it can be forced to turn. So we want to try to attach two window motors into a toughbox that we used last year in our winch that pulled us up the tower.
Does anyone have any ways/suggestions to get the window motors to work with the thoughboxes? One suggestion we had was to take a hacksaw to the plastic on the shaft so you just have the bare metal. But then how does that attach to a gear?
Unread 02-02-2011, 18:33
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Window motor to toughbox?
Carefull with your hacksaw. The last time I took a close look at the window motors that shaft does not turn.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 02-02-2011, 19:48
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
we just chain drive a sprocket and get the gear ratio that we need by using different size sprockets. We sometimes have to use a second set of sprockets to step it down to the desired speed
Unread 02-02-2011, 19:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
sprocket between two adapters would be the simplest.
Unread 02-02-2011, 20:34
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
most toughbox gearsets are very slow, however, with the KOP box this year, it provides 18 ft-lbs, and rotates 90 deg in ~1 sec
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 02-02-2011, 20:48
AKA: Brandon Liatys
Could you explain this? What adapters?
Unread 02-02-2011, 21:06
AKA: Brandon Liatys
Sorry for the double, but my main reason for wanting to use a window motor is because they don't backdrive
if there was another way we could stop motors from doing this, such as FP through the FP gearbox, that would be amazing...
Unread 02-02-2011, 21:21
From the KOP, Top of page 15, part # Denso-6 : Coupler, Denso motor, black, injection molded plastic, 6 tooth
Unread 02-02-2011, 21:42
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
The motor adapters are for interfacing with the plastic output of the motors. They are black plastic disks with conical protrusions extending from one face and have a center bore that accepts a keyed shaft on the cone and a bolt circle on the disk.
Unread 02-02-2011, 21:43
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
take what he suggested, put a keyed bar between the 2 adapters to hold it snug.. and put a sprocket on the bar somewhere. That's what were doing for some max lift power.
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 02-02-2011, 22:03
Joe Schornak's Avatar
Joe Schornak Joe Schornak is offline
No Stranger To Love
FRC #2840 (Blue Tide)
Joe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to behold
We've attached a window motor to a CIMplebox for our arm, but we had to machine a keyed adapter shaft to go from the plastic window motor adapter to the small gear. It seems to be working quite well so far; the gear reduction produces an ideal rate of rotation and sufficient torque to lift our manipulator.
A chain-based system would work, but you still have to find a way to attach the sprocket to a gear. The KOP sprockets are just too narrow to fit over the adapter without modification.
Either system would require a lot of structural support, since the window motor adapter isn't firmly attached to the motor axle. Bearings on the axle are also a good idea, to prevent cantilevering.
Also, the metal shaft doesn't rotate, so cutting away the toothed plastic bit won't do you any good.
1. Acquire Manual
2. Read Manual
3. ???
4. PROFIT!
Visit www.pcdsrobotics.org!
Unread 02-02-2011, 22:05
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
why dont use use code to put enough voltage on the fp to hold it in place, you'll have to fumble with the values a little bit to get it right, but its worked for us (offseason project). We did it with a cim on a toughbox though.
Unread 02-02-2011, 23:28
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Couldn't you easily cook the motor if it needed a significant amount of torque to hold up?
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 02-02-2011, 23:47
rutzman rutzman is online now
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
You could use the FP(or a Banebots motor, if you were so inclined) through a gearbox to turn a worm that turned a worm gear, essentially making a big window motor.
Unread 03-02-2011, 00:03
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
I don't recommend you put a window motor in a toughbox for one reason. A window motor in a toughbox would be SLOW. Window motors have a free speed of 84RPM (already pretty slow) by themselves and gearing that down to the 12.75:1 gear ratio of a standard Toughbox would give you a free speed of 6.6 RPM and a speed of 3.1 RPM at nominal torque.
Why don't you just use the window motors by themselves instead? In the KOP you got adapters for the window motors so you can attach the motors directly to a 5/8" shaft. Plus window motors have more than enough power by themselves to move just about anything you can ask them to. Just make sure you don't cantilever the shaft
Also you don't need a gearbox for the window motors because they already have one. The metal silvery thing sticking out the side of the window motor is a motor and the black part is the gear box which houses the worm gear (the reason window motors won't back drive). Before you get any ideas no you can't modify the window motor by separating the gearbox from the motor like you can with the Fischer price motors. The gear box is considered to be intergal to the motor which means you modify the gear box you modify the motor, which is against the rules. If you want a more explanation of window motor modification see this thread
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Last edited by Creator Mat : 03-02-2011 at 02:58. Reason: wrong window motor shaft size
