Go to Post used to find BBQ(Blue Banner Quotient) and SAUCE(Sextuple Advancement Uniform Counting Era)[URL="http://bbqfirst.x10host.com/index.php"]bbqfirst.x10host.com[/URL] Happy BBQing! - Beaker [more]
Unread 02-02-2011, 22:28
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
Re: Minibot Deployment Brainstorm!
Out deployer uses 2 pistons, one to push the deployer out, the other to deploy the minibot. We have prototyping videos (only using the deployer) on my youtube channel here: http://www.youtube.com/user/klmx30302 I would post individual links but I have 10+ vids of deployer testing.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 02-02-2011, 22:35
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Hmmmmmm! Interesting, very nice indeed! thank you for the reply! im going through the videos now! thank u for sharing!
RHS Senior 2011
Unread 02-02-2011, 22:48
wjr1965 wjr1965 is offline
FRC #0862
wjr1965 is an unknown quantity at this point
There has been some buzz about trying to standardize minibot deployment so that teams can get points for "coopertition" by lending their minibots to other teams. Deployment standardization would permit this to happen more easily.
Unread 02-02-2011, 23:28
Nemisis's Avatar
Frame/Body/Motors
That would be really smart wouldn't it? it would be sorta interchangeable am i correct? that way more than one type of minibot could be deployed from a single deployer? Rather ingenious!!
RHS Senior 2011
Unread 03-02-2011, 00:00
Nemisis's Avatar
Frame/Body/Motors
I apologize for the tardiness of my posts... for some odd reason the last two I've posted, it popped up and said that they would be posted as soon as a moderator had approved them.I'm Confused!
RHS Senior 2011
Unread 03-02-2011, 01:05
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
i believe what we intend to do is push the robot out, and then rotate the whole robot with the minibot on the end into the pole, that way the most power full motors, in a relatively ideal setup, will deploy the robot.
Unread 03-02-2011, 12:11
Nemisis's Avatar
Frame/Body/Motors
Oh thats cool! different from others I've heard! So your arm deploys it? Thank you for the reply! Good Luck!
RHS Senior 2011
Unread 04-02-2011, 16:24
mac mac is offline
AKA: Thomas (just give me a crabcake)McCubbin
FRC #0686 (Bovine Intervention/Jagbots)
mac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the rough
To all: Can the minibot change shape? We are using the battery to swing down.
As it climbs the pole. Gravity takes over. Keeping the wheels cocked onto the pole.
Thank You, Mentor Mac Team 686
Unread 04-02-2011, 16:57
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I see no rule that prohibits a minibot from changing shape, However <R91> must be complied with at all times
<R91> The MINIBOT may not exceed a 12” x 12” x 12” volume and weigh no more than 15 lbs.
___________________
- Tennyson, Ulysses
Unread 13-02-2011, 04:27
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
The standard deployment system is a slider or drawer system. Simply just slides out. . Its very good cause if most or all teams have the same type of deployment you can share minibot with other teams and visa-versa.
Unread 13-02-2011, 21:51
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
We are using pneumatics to push our bot onto the pole. For now, we can get it onto the pole by forcing it (the wheels are tensioned by rubber band and can be pushed open by forcing the minibot onto the pole and then it springs back to "grab" the pole (simple X design).
Edit: the distance traveled on the pole is 49" in case you were wondering.
http://www.youtube.com/user/stimp190.../0/TJAQzR_p85w
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
Unread 13-02-2011, 22:36
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
We are using the slide that came in the KOP and attached a 12 in pneumatic to it. It slides out quick. We hace a "V" on the end to help guide it with to virtical post to slide the mini bot onto. We have to add wheels under it so it can ride on the top of the platform to the pole. Fuzzy picture.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 14-02-2011, 01:06
Seathan93 Seathan93 is offline
AKA: Ian
FRC #1389 (The Body Electric)
Seathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to all
Wow, are we the only team with a deployment system that doesn't slide out?
we just have a box...and a flap goes down, and the minibot drives out onto the pole and then up it...we're close to getting it to work.
Unread 14-02-2011, 14:33
craigcd's Avatar
craigcd craigcd is offline
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
On team 2221 we are using a L shaped swing pivoted on a bar. The swing is spring loaded and triggered using a pneumatic cylinder.
Unread 14-02-2011, 17:49
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
The problem with that design is that although you can deploy your bridge earlier, making your minibot drive out rather than being on the end of that bridge you put out greatly increases the time it takes to deploy. Additionally, the extra fuctionality you need to make the minibot be able to drive on flat ground, then turn and drive up the pole translates to more complexity, more ways to go wrong, and more weight (meaning slower).
