Go to Post This is a game folks, and rules are rules, even if you kinda sorta broke one rule in the end its still broken - Mike Schroeder [more]
Unread 02-02-2011, 20:34
komeiji_koishi komeiji_koishi is offline
FRC #2035
komeiji_koishi is an unknown quantity at this point
Fixing Burnt Motors
Hey,
We kinda sorta burned out two of our motors for the minibot earlier this week, and we can't get any more of them because they're currently stuck in the Iowa snowstorm.
Could we open up our motors and fix them, and still compete with them?
[Team 2035]
Unread 02-02-2011, 20:39
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Fixing Burnt Motors
Originally Posted by komeiji_koishi View Post
Hey,
[Team 2035]
I don't think you could fix them,even if it was legal
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 02-02-2011, 20:43
For future reference, Team Update #5 specifically allowed teams to replace the 20A fuse that the Tetrix motors come with with an equivalent type of lower amperage. I guess there's a part that likes to fry at about 20A, so they're allowing that to be protected.
Unread 02-02-2011, 20:48
Chris is me's Avatar
AKA: Pinecone
The Tetrix motors don't have a fuse - what are you talking about?
Unread 02-02-2011, 20:54
Originally Posted by <R92-C>, as amended by TU#5
no more than one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057) except the 20A fuse may be replaced with an equivalent type of lower amperage,
OK, so it's the battery. But it's the motor part that is the problem, as noted in this sentence from the same Update: "Additionally, it has come to our attention that teams have burned out their Tetrix motors by stalling them while directly connected to the battery."
The motor has a part that lets the smoke out at about 20A. As such, teams are encouraged to replace the fuse on the battery pack or use the thermal protection wiring (allowed later in the rule as updated in TU#5).
Unread 02-02-2011, 20:55
ouellet348's Avatar
ouellet348 ouellet348 is offline
PTC Engineering Group Lead
AKA: Alexander Ouellet
no team (PTC)
ouellet348 is on a distinguished road
He means the fuse that is on the battery, it comes with a 20Amp fuse but by lowering it you can fix the issue with the motors burning out, in response to the fixing question the issue is a 3.9 ohm resistor that burns out at about 20amps. The resistor can be replaced but it is illegal to compete with in such a state, also to remove it it cause significant damage to the motor housing in the form of destroying the tabs bent to hold in the actual components. However if you can solder a bridge in and solder in a replacement resistor to outside of the motor for easy access, the motor will perform identically to a normal one for testing, so that you don't risk new ones. I'd advise using those for testing and running at most 15Amp fuses to fix the issue. good luck !
Unread 02-02-2011, 21:03
AKA: Pinecone
Doesn't really solve the poster's problem or answer their question, though. Their motors are burnt out.
Anyway - burnt out motors can't be repaired and remain competition legal, sorry.
Unread 02-02-2011, 21:10
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
If burnt motor means the "magic smoke left it" then I don't think its fixable.
Unread 02-02-2011, 21:17
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
It's easy, just get some magic red smoke, and put it back in!
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 02-02-2011, 21:30
Andy A. Andy A. is offline
Getting old
FRC #0095
A little clarification-
No, you can't modify the motors and still compete with them.
Additionally, you can't really fix a fried motor, at least not in the traditional sense. Whats burning is the insulating enamel on the wire coils of the armature. Once that coating is burnt off the wire starts to short against its self, decreasing the effective strength of the magnetic field it can generate. Torque decreases accordingly. The only way to 'fix' the motor is to either rewrap the coils with new wire (nigh impossible to do by hand) or replace the armature. For a small DC motor like this neither option makes any sense.
Mark the fried motor and use it for R&D purposes that don't require full power, or toss it.
You can buy new motors from Lego and Pitsco. $30 each and make sure you get the same part number!
Unread 02-02-2011, 21:36
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
RED????? Since when does magic smoke, or at least the type found inside electronics, come in such a color? Also, once the magic smoke is let out, it cannot be put back in, so even if you can get some, it is useless.
Unread 02-02-2011, 21:42
AKA: Brendan McLeod
Well, if the magic blue smoke comes out....it only makes sense to put the red stuff back in.......
Unread 02-02-2011, 22:56
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
The rules basicly say no modifications. Repair therefore should be legal. I think if you realize what the spirit of the rule is and do not push these limits you will be OK. You can absolutely repair it for your developement and testing and you can hope your new ones show up before the regional. You may carry in your minibot.
Unread 02-02-2011, 23:11
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
We fixed our burnt out motors only for use in prototyping, the fix we used would not allow the motor to be legal in competition.
This thread shows what we did.
http://www.chiefdelphi.com/forums/sh...ad.php?t=89848
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 03-02-2011, 08:41
komeiji,
***Note: Under current rules, this is not a legal modification of this motor!***
The method you would use to open these motors is first remove the transmission and adapter plate. Then I use a wire cutter to pull back the outer case at each point it has been crimped over the end plate. Using a long, slender tool, i.e. screwdriver, push gently on the gear and shaft to push the end plate and armature out of the case and magnet assy. Once you have The armature and brush assy open, you can gently move the brushes to release the armature. Inspect the armature to see if the wires are burned or are dark in color. If so, dispose of the motor it is not repairable. If everything looks normal, set the armature where it will not roll off the table. Look at the endplate with the brush assy. (The picture in the linked thread will help.)
You will note an axial leaded component that resembles a coated resistor. This is an inductor that is likely burned open. If you carefully unsolder this component, replace it with a short wire. Assemble the endplate and armature being careful to avoid damage to the brush assy. Then using a long slender tool, reinsert the endplate/armature assy back into the case. Try connecting a battery to the motor and see if it spins. If it appears to be working correctly, then using a hammer and some other tool, recrimp the case to hold the endplate in place. This will give you a working motor that is not legal for competiton.
