Re: Window motor to toughbox?
Couldn't you easily cook the motor if it needed a significant amount of torque to hold up?
I don't recommend you put a window motor in a toughbox for one reason. A window motor in a toughbox would be SLOW. Window motors have a free speed of 84RPM (already pretty slow) by themselves and gearing that down to the 12.75:1 gear ratio of a standard Toughbox would give you a free speed of 6.6 RPM and a speed of 3.1 RPM at nominal torque.
Why don't you just use the window motors by themselves instead? In the KOP you got adapters for the window motors so you can attach the motors directly to a 5/8" shaft. Plus window motors have more than enough power by themselves to move just about anything you can ask them to. Just make sure you don't cantilever the shaft Also you don't need a gearbox for the window motors because they already have one. The metal silvery thing sticking out the side of the window motor is a motor and the black part is the gear box which houses the worm gear (the reason window motors won't back drive). Before you get any ideas no you can't modify the window motor by separating the gearbox from the motor like you can with the Fischer price motors. The gear box is considered to be intergal to the motor which means you modify the gear box you modify the motor, which is against the rules. If you want a more explanation of window motor modification see this thread Last edited by Creator Mat : 03-02-2011 at 02:58. Reason: wrong window motor shaft size |
A window motor driving a toughbox with the second stage of gearing removed would be just about right to run an arm.
We thought about it a while and decided to use a V belt and pulley system, driven by a window motor, with a latex tube supporting the weight of the arm. Seems to work so far....but this is the prototype, not the finished product. One interesting thing about using a window motor with a geared or chained connection to the arm, is that you have to remove the robot from the field after the match, and if the arm is pointing up it's hard to get the arm back down. The belt lets it slip. Adjusting the belt tension so it slips when you want, and not when you don't, can be tricky. http://www.youtube.com/watch?v=3vY2_h2GBIs ![]() |
I would really suggest testing different approaches to make the fp with gearbox work, what is the weight being held on the end of the arm? You could use counter-weights, springs, surgical tubing, etc... to help offset the weight of the arm. Since the tubes do not weigh very much most of your weight is the mechanism. Play around with different systems, this way you won't overheat your motor.
You have it built already so make some modifications on it and actually test the performance. |
That's a good suggestion. We made our arm with a piece sticking out the back, that we can attach surgical tubing to. The tubing pulls the back of the arm (past the pivot about 4 inches) downward, which lifts the other end of the arm up. With 8 strands (two loops wrapped twice around) it does the job. We made an easily adjustable lower anchor so we can change the tension quickly to balance it just right.
Yeah, every time you run into a problem brainstorm the simplest ways first. In my Mech. Engineering courses in college we learned, on day one, "KISS" (Keep It Simple Stupid) and it really sums it up. What is easier? Adding some tubing? or devising a whole new gearbox system?
But keep working you guys are still making good time ![]() |
#8
FP and CIM motors are very, very different in how they are built and how much stall current they can handle before overheating.
#10
Ok, after more playing with the motors and gearboxes today, we figured out that window motors into the toughbox just wont happen.
Next thing were trying is two window motors powering a sprocket with 15 teeth, to a sprocket with something around 60 teeth. We have the 15 tooth sprocket, we just need to figure out what to use for the other one. Any suggestions? We can't machine our own stuff, so its whatever we can find..if we could just figure out a range of how many teeth on the bigger sprocket then we'd be good Last edited by Brandon_L : 03-02-2011 at 19:58. |
