Go to Post Life is unfair. Learn to deal with it or be unhappy. - Joe Johnson [more]
Unread 03-02-2011, 00:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Window motor to toughbox?
A window motor driving a toughbox with the second stage of gearing removed would be just about right to run an arm.
We thought about it a while and decided to use a V belt and pulley system, driven by a window motor, with a latex tube supporting the weight of the arm. Seems to work so far....but this is the prototype, not the finished product. One interesting thing about using a window motor with a geared or chained connection to the arm, is that you have to remove the robot from the field after the match, and if the arm is pointing up it's hard to get the arm back down. The belt lets it slip. Adjusting the belt tension so it slips when you want, and not when you don't, can be tricky.
http://www.youtube.com/watch?v=3vY2_h2GBIs
Unread 03-02-2011, 00:21
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
I would really suggest testing different approaches to make the fp with gearbox work, what is the weight being held on the end of the arm? You could use counter-weights, springs, surgical tubing, etc... to help offset the weight of the arm. Since the tubes do not weigh very much most of your weight is the mechanism. Play around with different systems, this way you won't overheat your motor. You have it built already so make some modifications on it and actually test the performance.
Good enough is the enemy of anything great!
team 1671
Unread 03-02-2011, 00:24
MrForbes's Avatar
AKA: Jim
That's a good suggestion. We made our arm with a piece sticking out the back, that we can attach surgical tubing to. The tubing pulls the back of the arm (past the pivot about 4 inches) downward, which lifts the other end of the arm up. With 8 strands (two loops wrapped twice around) it does the job. We made an easily adjustable lower anchor so we can change the tension quickly to balance it just right.
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Creator Mat View Post
I don't recommend you put a window motor in a toughbox for one reason. A window motor in a toughbox would be SLOW. Window motors have a free speed of 84RPM (already pretty slow) by themselves and gearing that down to the 12.75:1 gear ratio of a standard Toughbox would give you a free speed of 6.6 RPM and a speed of 3.1 RPM at nominal torque.
7 RPM is not that bad for an arm!
Unread 03-02-2011, 00:31
FRC #5817 (Uni-Rex)
Yeah, every time you run into a problem brainstorm the simplest ways first. In my Mech. Engineering courses in college we learned, on day one, "KISS" (Keep It Simple Stupid) and it really sums it up. What is easier? Adding some tubing? or devising a whole new gearbox system?
But keep working you guys are still making good time
team 1671
Unread 03-02-2011, 02:35
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Originally Posted by Trent B View Post
Couldn't you easily cook the motor if it needed a significant amount of torque to hold up?
We had about 40 lbs on our cim/toughbox setup without a problem, but it will take experimentation with the FP. Definitely try it out and abuse it before you use it on the real bot if you do decide to try it. Better cook it now than in comp (hopefully it wont cook though)
Unread 03-02-2011, 10:13
MrForbes's Avatar
AKA: Jim
FP and CIM motors are very, very different in how they are built and how much stall current they can handle before overheating.
Unread 03-02-2011, 19:52
doot doot
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Ok, after more playing with the motors and gearboxes today, we figured out that window motors into the toughbox just wont happen.
Next thing were trying is two window motors powering a sprocket with 15 teeth, to a sprocket with something around 60 teeth. We have the 15 tooth sprocket, we just need to figure out what to use for the other one.
Any suggestions?
We can't machine our own stuff, so its whatever we can find..if we could just figure out a range of how many teeth on the bigger sprocket then we'd be good
