Go to Post Test your code and your assumptions. - ShotgunNinja [more]
Unread 03-02-2011, 01:45
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
pic: 179 Progress
Unread 03-02-2011, 01:50
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: 179 Progress
Awesome concept! I love unique approaches like this, can't wait to see how it turns out. Also digging the tubular arm construction and spring loaded minibot deployment mechanism. Fits together nicely!
What's the weight of everything pictured?
Unread 03-02-2011, 08:18
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
I think I would be worried about deformation of the plate at the attachement points of the tower. Are there plans to reinforce those areas?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 03-02-2011, 09:07
Swampdude's Avatar
AKA: Dan Quiggle
It's extremely light, I'm guessing 50lbs right now. We're going to add 1x1 steel angle on the underside around the perimeter for ballast and strength. Maybe a couple lateral members in there as well if things look too flimsy. But it's pretty rigid as is, and the bumper corners will get beefed up. I just thought it made sense to take advantage of the bumper strength. Has anyone else done this before?
www.179swampthing.org
Unread 03-02-2011, 15:47
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Very interesting,
I would personally be scared to do something like this because of high speed collisions, but if you add the 1x1 steel angle then it should be fine. Then again we tend to make our frames more beefy than they need to be .
I do love how easy it makes to work on the robot, and also easy to manufacture. Can't get much better than having a frame done after a water-jet run.
Also, I like the mini-bot deployment system. Does it just work using the weight of the mini-bot to compress the springs in the vertical position and then extend when horizontal?
Very cool concept Dan, can't wait to see it in person.
Is there a Swamp Scrimmage this year?
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 03-02-2011, 16:12
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
a student cut his thumb open the baseplate and got blood all over last night. its an omen for a great season.
Unread 03-02-2011, 17:10
Swampdude's Avatar
AKA: Dan Quiggle
Thanks Dave,
It's got a rotating latch that holds it upright and coiled, rotates 90 and releases. And I think we're doing the scrim, however I got an email from team 1543, and they are coordinating a "robot ruckus" scrim in Orlando on the 19th. I need to find out the plans. It would be nice to have a real scrim on a full field with more teams. But we'll announce ours soon if we're doing it on the 19th as well. Would you guys come?
Unread 03-02-2011, 17:12
Chris is me's Avatar
AKA: Pinecone
That is an incredibly innovative use of bumpers.
Unread 03-02-2011, 17:18
AKA: Dave
Originally Posted by Swampdude View Post
Thanks Dave,
Yes, most likely we will be able to make it this year. For the past 3 years we have had to finish our robots on that last weekend, but right now we are on schedule and should have a completed robot by then if all goes as planned.
Your place is only about 45 minutes from our place, but Orlando is a long drive for the team so I'm not sure we would go that far.
Last time we were there it was also Tubes for game pieces
Unread 03-02-2011, 20:03
gopatterson gopatterson is offline
FRC #3045
gopatterson is an unknown quantity at this point
What is the legal height of the bummper for this years competiton we were going on last years i think that said 10"
Unread 03-02-2011, 20:09
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
The bumper zone this year is much lower: 1"-7"
Unread 03-02-2011, 21:19
waialua359's Avatar
waialua359 waialua359 is online now
AKA: Glenn
FRC #0359 (Hawaiian Kids)
On bottom left portion of picture, minibot deployment via springs right?
Unread 03-02-2011, 23:43
Swampdude's Avatar
AKA: Dan Quiggle
Hi Glenn,
Yes.... Boing, smack, rrrrrrrrrrrrrrrrr, ding ding ding, yay!
Unread 03-02-2011, 23:53
AKA: Pinecone
Don't do this. PLEASE read the manual.
Unread 04-02-2011, 01:17
waialua359's Avatar
AKA: Glenn
Hi Glenn,
