Go to Post But here's the beautiful thing about FIRST: you are supposed to make mistakes. - RunawayEngineer [more]
Unread 03-02-2011, 12:09
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
captainking is an unknown quantity at this point
Re: Encoder Problems
Wiring:
5v -> power on dio 4
gnd -> gnd on dio 4
A - signal on dio 4
B -> signal on dio 5
Programming in the pictures
I have DIOs set to 4 for A and 5 for B
Name:	encoder teleop.JPG
ID:	9940  Click image for larger version
Name:	encoder begin.JPG
Integrity first
Service before self
Excellence in all we do
Unread 03-02-2011, 12:13
don't call the encoder config timer and start in telop. It will get called 50 times a second. Put them in begin, instead.
Unread 03-02-2011, 12:22
Using controls instead of constants for the channel numbers will work if you're going to run Robot Main. Make sure to use the popup menu to set the current value as the default before you build the project. But I think it's simpler to use constants instead.
Unread 03-02-2011, 12:38
Level 85 Programmer
FRC #0168 (MIB)
We changed the controls to constants and moved the timer configure to the begin VI, but it still doesn't work.
Integrity first
Service before self
Unread 03-02-2011, 12:56
On the dashboard, when you spin the encoder, do you see the DIO change states?
Unread 03-02-2011, 13:11
Level 85 Programmer
FRC #0168 (MIB)
We see nothing change on the dashboard, but we are using the dashboard on my personal computer, not the classmate
Name:	dashboard encoder.JPG
Integrity first
Service before self
Unread 03-02-2011, 13:29
Does your code now resemble this example?
Unread 04-02-2011, 08:15
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Take a look and get the encoder example working first. Then integrate that code into your robot code. Here are a few steps:
1. From the LabVIEW Getting Started Window, click on "Find FRC Examples".
2. in the Sensors folder of the Example Finder, open the encoder example and get that to work.
3. Back at the Getting Started Window (View>>Getting Started Window if you have VIs open), check out Tutorial 7 - Integrating Examples into Robot Code.
Doug Norman
