Go to Post A lot of the time in FIRST it's not what you have when you enter the program, but what you gain from being in it. - Elgin Clock [more]
Unread 03-02-2011, 02:58
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Minibot Deployment Brainstorm!
Originally Posted by Nemisis View Post
Ah nice! thank You for the Reply! Our team thought about using a pneumatic cylinder for that too, however we've already got two being used, one to raise our arm and the other for the grabber at the end... and with using a single small compresser, we dont really want to use any more cylinders. We're using the largest cylinder that Bimba makes! i think its like 2 feet long nearly! lol Thank You again for sharing!
Are you using a storage tank(s) in addition to the compressor? While the new compressor is physically smaller than previous years it's performance is actually higher. Here is the spec sheet for the legal compressor family. http://www.viaircorp.com/OnRoad/90C.html
Unread 03-02-2011, 12:11
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Oh thats cool! different from others I've heard! So your arm deploys it? Thank you for the reply! Good Luck!
RHS Senior 2011
Unread 04-02-2011, 16:24
mac mac is offline
AKA: Thomas (just give me a crabcake)McCubbin
FRC #0686 (Bovine Intervention/Jagbots)
mac is a name known to allmac is a name known to allmac is a name known to allmac is a name known to allmac is a name known to allmac is a name known to all
To all: Can the minibot change shape? We are using the battery to swing down.
As it climbs the pole. Gravity takes over. Keeping the wheels cocked onto the pole.
Thank You, Mentor Mac Team 686
Unread 04-02-2011, 16:57
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I see no rule that prohibits a minibot from changing shape, However <R91> must be complied with at all times
<R91> The MINIBOT may not exceed a 12” x 12” x 12” volume and weigh no more than 15 lbs.
___________________
- Tennyson, Ulysses
Unread 12-02-2011, 23:53
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Here is a quick video that shows my team's deployment system.
http://www.youtube.com/watch?v=QTh59TiHde4
We still need to cut a channel in the Plexiglass for the pole and we need to figure out how the minibot will attach to the plate, but the core of the system is there. We used a pneumatic cylinder and a 4-joint scissor lift with the sliders. The mechanism goes from 0 (totally inside the robot's perimeter) to 22 inches (touching the pole) in about 1.4 seconds. The maximum extension, like I said, is 22 inches, which gives us some space for the channel and for alignment error.
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 13-02-2011, 03:41
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Looks very good, guys. I know that drawer slide set from Amerock. 3#10oz and very sturdy. We're trying pneumatic actuation too with a two-arm linkage. that's quite a pile of washers you've got on the end there!
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 13-02-2011, 04:27
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
The standard deployment system is a slider or drawer system. Simply just slides out. . Its very good cause if most or all teams have the same type of deployment you can share minibot with other teams and visa-versa.
Unread 13-02-2011, 21:51
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
We are using pneumatics to push our bot onto the pole. For now, we can get it onto the pole by forcing it (the wheels are tensioned by rubber band and can be pushed open by forcing the minibot onto the pole and then it springs back to "grab" the pole (simple X design).
Edit: the distance traveled on the pole is 49" in case you were wondering.
http://www.youtube.com/user/stimp190.../0/TJAQzR_p85w
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
Unread 13-02-2011, 22:36
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
We are using the slide that came in the KOP and attached a 12 in pneumatic to it. It slides out quick. We hace a "V" on the end to help guide it with to virtical post to slide the mini bot onto. We have to add wheels under it so it can ride on the top of the platform to the pole. Fuzzy picture.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 14-02-2011, 01:06
Seathan93 Seathan93 is offline
AKA: Ian
FRC #1389 (The Body Electric)
Seathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to all
Wow, are we the only team with a deployment system that doesn't slide out?
we just have a box...and a flap goes down, and the minibot drives out onto the pole and then up it...we're close to getting it to work.
Unread 14-02-2011, 14:33
craigcd's Avatar
craigcd craigcd is offline
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
On team 2221 we are using a L shaped swing pivoted on a bar. The swing is spring loaded and triggered using a pneumatic cylinder.
Unread 14-02-2011, 14:53
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
We are using a box with one side on a hinge to act as a draw bridge out to the pole. We are still working out how to get the minibot across the bridge
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
Unread 14-02-2011, 17:49
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
The problem with that design is that although you can deploy your bridge earlier, making your minibot drive out rather than being on the end of that bridge you put out greatly increases the time it takes to deploy. Additionally, the extra fuctionality you need to make the minibot be able to drive on flat ground, then turn and drive up the pole translates to more complexity, more ways to go wrong, and more weight (meaning slower).
Unread 14-03-2011, 00:02
jhusser's Avatar
jhusser jhusser is offline
FRC #2221 (Robo Dawgs)
jhusser is on a distinguished road
are team is using a swing arm and spring for deployment letting gravity do all the work
