Go to Post -dave "The Circular Saw of FIRST" lavery - dlavery [more]
Unread 03-02-2011, 11:34
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
captainking is an unknown quantity at this point
Encoder Problems
Hey, we're having some troubles with the Digital Encoder
I believe we have it wired right as the light is coming on, but whenever we run the program, I'm not getting any values for either rate or distance.
I've checked the code and we have the right DIO ports assigned to A and B.
Any ideas?
Integrity first
Service before self
Excellence in all we do
Unread 03-02-2011, 11:50
Re: Encoder Problems
Originally Posted by captainking View Post
Any ideas?
Not without some details from you, no.
"I believe we have it wired right" doesn't let us know if what you believe is true. Tell us how you have it wired and let us decide if there's something amiss.
"I've checked the code" doesn't let us know if the code is correct. Show us the program and let us see if it's doing what you think it should be doing. We can also tell you if what you think it should be doing is actually what it needs to do.
Unread 03-02-2011, 12:09
Level 85 Programmer
FRC #0168 (MIB)
Wiring:
5v -> power on dio 4
gnd -> gnd on dio 4
A - signal on dio 4
B -> signal on dio 5
Programming in the pictures
I have DIOs set to 4 for A and 5 for B
Name:	encoder teleop.JPG
ID:	9940  Click image for larger version
Name:	encoder begin.JPG
Integrity first
Service before self
Unread 03-02-2011, 12:13
don't call the encoder config timer and start in telop. It will get called 50 times a second. Put them in begin, instead.
Unread 03-02-2011, 12:22
Using controls instead of constants for the channel numbers will work if you're going to run Robot Main. Make sure to use the popup menu to set the current value as the default before you build the project. But I think it's simpler to use constants instead.
Unread 03-02-2011, 12:38
Level 85 Programmer
FRC #0168 (MIB)
We changed the controls to constants and moved the timer configure to the begin VI, but it still doesn't work.
Integrity first
Service before self
Unread 03-02-2011, 12:56
On the dashboard, when you spin the encoder, do you see the DIO change states?
Unread 03-02-2011, 13:11
Level 85 Programmer
FRC #0168 (MIB)
We see nothing change on the dashboard, but we are using the dashboard on my personal computer, not the classmate
Name:	dashboard encoder.JPG
Integrity first
Service before self
Unread 03-02-2011, 13:29
Does your code now resemble this example?
Unread 04-02-2011, 08:15
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Take a look and get the encoder example working first. Then integrate that code into your robot code. Here are a few steps:
1. From the LabVIEW Getting Started Window, click on "Find FRC Examples".
2. in the Sensors folder of the Example Finder, open the encoder example and get that to work.
3. Back at the Getting Started Window (View>>Getting Started Window if you have VIs open), check out Tutorial 7 - Integrating Examples into Robot Code.
Doug Norman
