Go to Post I believe it is healthy to leave FIRST at some point and carry on with a well-rounded life (family, fun, school, & work). Focus your creative energy on developing your skills as a professional; then, come back to FIRST as a mentor later down the line. - Erin Rapacki [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 28-01-2011, 19:10
Shantali Shantali is offline
FRC #3609
Shantali is an unknown quantity at this point
Single Joystick Tank Drive
Hi all,
I'm programming for rookie team. I barely have any experience with Java or robotics for that matter.
My goal is to make the robot drive with a single joystick in differential "tank" drive.
Here's the schematic that I found that would be ideal...
http://web.goodrobot.com/blog/wp-con.../tankdrive.png
I'm using Iterative robot template.
Any help would be greatttly appreciated!
J
Unread 28-01-2011, 19:12
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Single Joystick Tank Drive
the only thing i can think of is you do something like this
...tankDrive(leftstick,leftstick)
that might work
Unread 28-01-2011, 19:48
What you are describing is similar to (or maybe identical) to arcade drive, which is already built in.
that might work
This would result in the robot going forward and backwards with the left stick y axis, but never turning.
Unread 28-01-2011, 19:51
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
I can't find the related documentation/source (I'll keep looking and revise my answer as necessary), but it's probably not possible to do with the pre-made TankDrive class. And actually, I see more in common with the ArcadeDrive and your desired style than Tank.
I would say that you'll either need to find some code a previous team wrote or extend Tank/ArcadeDrive (or just starting from scratch, it'll end up being a combination of both, really). And take the ArcadeDrive code but set the two sets of motors depending on the combination of x,y values.
Unread 28-01-2011, 20:52
Originally Posted by Shantali View Post
Hi all,
J
Try this:
// Xj,Yj are the joystick readings
L = -Yj+Xj;
R = -Yj-Xj;
max=abs(L); if(max<abs(R)) max=abs(R);
if(max>1){L/=max; R/=max;}
send "L" to the left wheels and "R" to the right wheels
Unread 28-01-2011, 21:31
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
As far as I can tell from your description, you are describing Arcade drive exactly. It takes an x and y axis, and outputs to 2 or 4 motors similar to tank drive.
In other word, full left on the joystick would make the right side go full forward, and left side go full backwards. Full right would make right go full backward, and left go full forwards. And so on.
Unread 28-01-2011, 21:44
Some drivers find the following a bit more intuitive to drive:
if(Yj<=0){L=-Yj+Xj; R=-Yj-Xj;}
else {L= -Yj-Xj; R=-Yj+Xj;}
max=abs(L); if(max<abs(R))max=abs(R);
Unread 29-01-2011, 20:58
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Use the arcade drive method in Joystick. It will do EXACTLY what you want it to do.
Unread 30-01-2011, 20:00
FRC #3609
Thanks for the responses!
I got it working with
m_robotDrive.arcadeDrive(m_driveStick.getY(), m_driveStick.getX());
It does everything as intended, but there's something i'd like to change.
Right now it goes forward, back, turns on the spot and strafes forward perfectly.
But if trying to pull the joystick back-left, the left motor is working 100% backwards, which essentially moves the robot's back to the right. If pulling back-right, the right motor is working 100% backwards, which moves the robot back to the left. Intuitively when trying to do that, you'd expect it to work like a car would, turning left would make the back go left..
I would like to change that so drivers could have it more intuitively.
I will post when/if I figure it out. Again, thanks everyone for taking the time.
J
Unread 30-01-2011, 20:05
That's what this is supposed to do. Try it.
Unread 02-02-2011, 00:18
FRC #3609
I was trying to work around that using
double m_y = m_driveStick.getY();
double m_x = m_driveStick.getX();
if (m_y >= 0) //the Y axis is inverted, so going forward is negative number
    m_x = 0-m_x; //inverting X value
m_robotDrive.arcadeDrive(m_y, m_x);
The problem I faced with that was that the joystick wasn't giving me a perfect 0.. I added a simple println statement to get the y values, and it ranged anywhere from -0.3 to 0.3...
Ether, it looks like your solution
would have the same problem.
I tried something like if m_y >= -0.3, but it results in motors rapidly switching directions if starting slowly..
Another possible solution would be treating anything within .2 or so from the axis as 0.. but it doesn't seem like the best way of doing it either.
Thanks in advance,
j.
Unread 03-02-2011, 11:51
Are you saying you got readings in the range -0.3 to 0.3 for Y when the joystick was in the null position?
Unread 03-02-2011, 13:44
FRC #3609
Yup
Unread 03-02-2011, 13:48
Try a different joystick.
Unread 03-02-2011, 15:12
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
I believe you can also go into the windows control panel, find the Game Controllers adapter and use it to center the joystick (ie, the joystick reads 0,0 when centered).
The views expressed are mine and should not be construed to represent the views of anyone else.
