Go to Post The world isn't made out of Nerf, you will get scrapes and bruses, but you will get back up and continue on. If you watch out you can avoid the sharp edges. - Joe Matt [more]
Unread 03-02-2011, 15:41
MechanicMaster MechanicMaster is offline
FRC #2876
MechanicMaster is an unknown quantity at this point
Spike Breaker
how is the spike breaker used in the pneumatic system?
does it regulate the solenoid?
Unread 03-02-2011, 15:45
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Spike Breaker
The breaker/fuse in a spike relay protects the circuit from drawing too much current. Typically, pneumatic devices are a very low-demand application as far as electric current, but in the case of a short or similar malfunction, the breaker will shut the circuit down.
The spike itself is wired to the digital sidecar, and used to turn a solenoid on or off, if you do not have any ports available in the pneumatics breakout.
Unread 03-02-2011, 16:09
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Spike Breaker
If you are using Labview, take a look at the Compressor VI in the examples. It shows you how to wire AND program the pneumatic system.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 03-02-2011, 16:16
Re: Spike Breaker
Mechanic,
A spike is needed to turn the compressor on and off. This is used with the compressor VI in Labview by reading the pressure switch and turning the Spike on. Spikes can also be used to control pneumatic solenoids but the solenoid module for the Crio is easier to implement from a wiring standpoint.
As a reminder, if you use the Spike for controlling a compressor, you should replace the 20 amp fuse in that Spike with a 20 amp circuit breaker.
