Re: LabView Problem
If you just want to run the Driver Station/Dashboard applications on the Classmate and not use it for LabVIEW program development, then what you listed should be all you need. That's the correct order, too.
The Vision tools needed by the Dashboard are included as part of the KOP image stick installation.
If you want to use the Classmate for programming then you have to install the LabVIEW DVD (via a thumb drive copy or an external USB-DVD drive).
