Go to Post A video is worth 30,000 words a second. - Thromgord [more]
Unread 03-02-2011, 02:19
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Caster Wheels
Just an quick reality check but using 2 drive wheels in the back and 2 casters in the front is full legal corrected? Looked over the rules and it seems fine, but just want to make 100% sure.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 03-02-2011, 02:22
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: Caster Wheels
if they fall within the list of allowable parts (all tetrix wheels or made out of the allowed materials) then you should not have a problem
Unread 03-02-2011, 02:52
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Re: Caster Wheels
Using caster wheels is legal. However I suggest if you can, invest in some omni wheels if you want a 2 wd, 4 wheel design. In 2008, our rookie year we had a horrible experience with caster wheels. If you are using the kit base you could easily add the Omni wheels.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 03-02-2011, 03:45
dtengineering's Avatar
AKA: Jason Brett
Re: Caster Wheels
I believe this advice is intended for the minibot, while the question (I assume) refers to the robot, or hostbot, or whatever the big machine is called.
Casters are certainly legal, but you may wish to consider omniwheels instead. I'm sure if you search CD (or google) for discussions of casters and omniwheels you will find that omnis are often a preferred solution for a number of very good reasons.
Jason
P.S. If you are doing a four wheeled robot with two wheel drive, remember to keep as much weight as possible over the two driven wheels.
Unread 03-02-2011, 03:48
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Re: Caster Wheels
We also had a bad experience with caster wheels in 2008. Won't ever use them again. I too would suggest omni wheels.
Unread 03-02-2011, 08:03
Re: Caster Wheels
Mk,
Casters are perfectly acceptable but have drawbacks. When moving from a forward to reverse direction the cater must rotate about it's vertical axis which requires some side to side motion to accomplish. If the robot is in a position that it cannot move sideways, the casters will actually fight your commands. Other robots can direct your robot actions by pushing on the side of the robot where the casters are located. Omni wheels react the same way.
On tilted surfaces, they have a mind of their own. While they may work this year, in a year where climbing, ramps, or bumps are part of the game, casters are by far from the best choice.
Unread 03-02-2011, 08:42
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Caster Wheels
We have a few rules on team 829.
Drive train rule number 1. No casters.
Unread 03-02-2011, 08:50
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Caster Wheels
816 has the same rule.
MK.32, have you looked into using a simple omni-directional wheel in place of a caster? Here's a link: http://www.andymark.com/searchresults.asp?cat=69
A pair of Omni wheels should give you similar turning ability but they will be much more predictable and have a slightly higher resistance to pushing than a caster, and you can power them if you wanted to.
-Dustin Benedict
Unread 03-02-2011, 11:25
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: Caster Wheels
From experience, casters are flat out terrible for FRC.
Omni wheels are the way to go for what you want to do.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 03-02-2011, 11:44
Re: Caster Wheels
Slippery skid plates might even be preferable to caster wheels. At least they don't put up a fight when you want to change direction.
Unread 03-02-2011, 11:54
pfreivald's Avatar
AKA: Patrick Freivald
Re: Caster Wheels
A well designed ball caster might vaguely be acceptable, but not really. Casters are NOT your friend.
Also, if you choose to ignore the general advice given here about not using casters, put your drive wheels in front if you at all can -- it makes it a lot easier to line up on things properly if the front of the robot isn't pivoting around the back.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 03-02-2011, 18:23
Mk.32's Avatar
AKA: Mark
Re: Caster Wheels
Thanks for feedback.
We will be switching to something else for sure.
Are the plastic omni-directional wheel fine or are the steel ones that much better?
Unread 03-02-2011, 18:30
Re: Caster Wheels
Either one should work.
Also, consider adding a chain run to power the omniwheels. You get more forward power, without affecting sideways motion of the omnis.
Unread 03-02-2011, 19:28
zbanks zbanks is offline
AKA: Zach Banks
FRC #0529 (Mansfield Hornets)
zbanks is an unknown quantity at this point
Send a message via AIM to zbanks
Re: Caster Wheels
Not to hijack this thread, but...
Our team was planning on using ball casters with CWD. We have a drive platform and its incredibly maneuverable.
3 years ago, we used omniwheels on a 4-wheeled robot for slippage, and it worked pretty well. However, it was a huge pain when they broke, considering how expensive they were.
Apparently, (before my time, and there's not a whole lot of recollection about them, which could be good or bad) about 5-6 years ago we used a similar design to now. It was claimed to have great maneuverability, but if you dropped the robot or anything, the casters could dent, which would prevent them from rolling correctly. However, they're cheap enough where you can easily have extras on hand.
This year, when we designed the robot, we chose ball casters based mostly on these experiences. We assume that omnis would not provide any significant prevention from being pushed and rotated around our center. We were also being cost-conscious, being a pretty low-budget team. Plastic omnis would have been about 4x as much as a heavy-duty ball casters, which are also readily available at a hardware store.
Since we're using direct drive, powering omnis wouldn't be worth the hassle, either.
Basically, I want to make sure that our decision was sound. Based on our pretty limited test, it seems to work pretty well, but that means nothing in FIRST Has anyone had any trouble with ball casters?
Unread 03-02-2011, 20:31
Re: Caster Wheels
If you must use a caster, ball casters are about the best to use. As long as they aren't acting like swivel casters, that is.
I believe the AM omnis have had a strengthening redesign since about 3 years ago, too.
