Go to Post They have obviously figuered out something special. I want to learn from them. - dlavery [more]
Unread 03-02-2011, 18:15
WillF WillF is offline
Team Captain
FRC #2945 (B.A.N.G (Bolts and Nuts Gang))
WillF is an unknown quantity at this point
Connecting to the cRIO with windriver
So we are trying to get our cRIO connected to the computer that we are developing on. So far we have set our IP address to the right IP (10.29.45.6) but we are still running into issues. We keep getting errors and are not able to connect. Has anyone else run into this issue?
Unread 03-02-2011, 18:35
d100n d100n is offline
FRC #3226
d100n is an unknown quantity at this point
Re: Connecting to the cRIO with windriver
Same here, I try to deploy the code but a loading bar never appears and it doesn't get downloaded onto the cRIO, I don't know what to do.
Sincerely,Team 3226
Unread 03-02-2011, 19:33
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Have you imaged your CRIO successfully? If so, try to ping the CRIO from the laptop at 10.29.2.
If you are tethered to port 1 on the crio, try turning off the wireless on the laptop (if its on).
If wireless, make sure the laptop is on the right wireless network, which should be your team number.
Brian K
Team 1225 Robotics Mentor
Unread 03-02-2011, 19:56
Team Captain
So we can ping it and we have no wireless so that is not an issue. Attached are the errors we keep getting.
ID:	9947  Click image for larger version
Unread 05-02-2011, 15:03
Azrathud's Avatar
Azrathud Azrathud is offline
Computer Nerd
AKA: Bryce Guinta
FRC #2945 (BANG)
Azrathud is on a distinguished road
Problem solved! We had to set the kernel image file path to C:\WindRiver\WPILib\vxWorks for the connection to work.
