Re: Custom Dashboard
OK but the classmate doesn't have labview to open the dashboard project
What language are you using to program?
if you are using another language just copy the three files to the classmate but the classmate needs LV to run the dashboard and driver station and it should have came with it. |
The LV development environment is needed to modify and build a new LV dashboard. You then put the dashboard executable into the Program Files/FRC Driver Station directory and naming it Driver Station.exe. To run the built driver station, you only need the runtime engine installed.
Greg McKaskle |
OK, then just copy the files on to a flash drive and replace the ones on the computer with your custom one
