Go to Post Break Robot. Re-engineer. Repeat! - Mr MOE [more]
Unread 03-02-2011, 17:02
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
cRIO problems
The cRIO imaging tools says No cRIO devices found, recheck network connection. We have the ethernet cord directly from the classmate pc to the cRIO. The power is working properly on the robot, but it has the status flashing orange. We have the IP configed at 10.6.40.6 and it doesnt work.
Unread 03-02-2011, 19:37
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: cRIO problems
If you have wireless on on the laptop turn it off. Sometimes the imaging software gets confused if you have more than one network adapter. Make sure its plugged into port 1. Use a straight cable, not crossover.
Brian K
Team 1225 Robotics Mentor
Unread 04-02-2011, 10:07
FRC #0640
Re: cRIO problems
Which color wire is the straight cable? We have wire directly connected from the classmate to the cRIO, but it says local area connection unplugged and we have the wireless turned off and its plugged into port 1
Unread 04-02-2011, 16:20
FRC #0640
Re: cRIO problems
got it working
Unread 05-02-2011, 08:27
Re: cRIO problems
Would you mind letting us know what the problem was? It might help someone else later who is having the same problems.
