Go to Post Being the GDC is not an easy job, anything can happen. Lunacy happened ::rtm:: - Conor Ryan [more]
Unread 03-02-2011, 18:19
Robobuff1.0's Avatar
Robobuff1.0 Robobuff1.0 is offline
FRC #1633
Robobuff1.0 is an unknown quantity at this point
Custom Dashboard
So I am failing to understand the custom dashboard. I have made the project and have gone through tutorial 6 and 7 in the LABVIEW programming guide. I just don't understand how to get it onto the Classmate.
Unread 03-02-2011, 18:55
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Custom Dashboard
Their are three files on the classmate that you need to replace.
Go to your project and build the project, next right click and explore the files.
You should get three files (the first named FRC Dashboard and two others).
next find those files on the C drive and replace the ones that are there with yours (make sure the names match what was their before)
Expect the best, Prepare for the worst
Unread 03-02-2011, 19:10
FRC #1633
is the building done on the classmate?
Unread 03-02-2011, 19:13
AKA: Jon
yes, it is done on the classmate or what ever computer you're going to use the dashboard on
Unread 03-02-2011, 19:38
FRC #1633
OK but the classmate doesn't have labview to open the dashboard project
Unread 03-02-2011, 19:54
AKA: Jon
What language are you using to program?
if you are using another language just copy the three files to the classmate but the classmate needs LV to run the dashboard and driver station and it should have came with it.
Unread 03-02-2011, 20:27
The LV development environment is needed to modify and build a new LV dashboard. You then put the dashboard executable into the Program Files/FRC Driver Station directory and naming it Driver Station.exe. To run the built driver station, you only need the runtime engine installed.
Greg McKaskle
Unread 03-02-2011, 20:41
AKA: Jon
OK, then just copy the files on to a flash drive and replace the ones on the computer with your custom one
