Go to Post Desperation is the mother of accomplishment. - Koko Ed [more]
Unread 03-02-2011, 19:54
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Custom Dashboard
What language are you using to program?
if you are using another language just copy the three files to the classmate but the classmate needs LV to run the dashboard and driver station and it should have came with it.
Expect the best, Prepare for the worst
Unread 03-02-2011, 20:27
The LV development environment is needed to modify and build a new LV dashboard. You then put the dashboard executable into the Program Files/FRC Driver Station directory and naming it Driver Station.exe. To run the built driver station, you only need the runtime engine installed.
Greg McKaskle
Unread 03-02-2011, 20:41
AKA: Jon
OK, then just copy the files on to a flash drive and replace the ones on the computer with your custom one
