Go to Post Here we go again with all kinds of speculation. We can never out guess FIRST. - BobC [more]
Unread 03-02-2011, 20:02
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Comms Not Working
We have configured the router and laptop to work together and communicate with each other as per the instructions on the KOP website. When I start up the driver station, the Bridge and Robot lights are both green. As I understand it, this should mean the robot works, but I still am not getting comms.
The only obvious problem I have seen is that when I connect to our wireless network (1997) it says I have limited connectivity. When I tether, it works just fine. What do I need to do to make sure that the connectivity is NOT limited?
Or any other ideas as to why this isn't working?
Thank you for any and all help in advance.
Unread 03-02-2011, 22:28
Re: Comms Not Working
The "limited connectivity" just means there's no route to the internet. Don't worry about it.
Those two green lights tell you that the devices are reachable on the network. The other Communication and Robot Code lights are the ones you probably want to focus on, right?
Tell us what the Robot Signal Light (RSL) is doing. Is it off? On? Flashing slow, flashing fast, winking off briefly every second or two, or what?
Unread 04-02-2011, 08:32
dmitch's Avatar
I am speaking from memory but I believe it is flashing steadily with the jaguars, sort of the "standby" when I dont yet have comms.
I will be able to give you a definite answer tonight around 5 after we work on the robot for the night.
Thank You!
Unread 04-02-2011, 23:34
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
I am assuming you are using remote dashboard, not local dashboard. Also Have your tried clicking enable I mean since you got the green lights do you see voltage on your dashboard display? If you are then you are getting comms. If that is the case then it might be your code that is not setup right O.o
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
