Go to Post Force yourself now, today, to learn one new thing each day. When you lay down on your fluffy pillow at night, before you say your prayers, ask yourself if you have learned anything new. If the answer is "NO" then you better get up and find something. - Al Skierkiewicz [more]
Unread 03-02-2011, 20:25
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Following Line Sensors
Hi I'm a rookie programmer and I was wondering how I should change the LabView autonomous code to work with our mecanums if we align the sensors as the autonomous code shows.
Basically, what all do we need to change, and does it automatically drive itself. But mostly how to work with mecanums.
Unread 03-02-2011, 20:45
Re: Following Line Sensors
The default code uses the Arcade form of Robot Drive. Since your robot teleop function has been modified to be able to drive and steer the robot, try making similar change to the autonomous.
The two control elements used in autonomous are the steering amount and forward velocity. The line sensors determine whether to drive left, right, straight, or stop. Try to use the mecanum version of drive to perform these actions, and perhaps put the code into the case statement.
Greg McKaskle
Unread 03-02-2011, 20:46
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
You can use the arcade drive.vi to move the robot you don't need the mecanum.vi unless you want to strafe
Expect the best, Prepare for the worst
Unread 04-02-2011, 08:22
dmitch's Avatar
Ok I will just wire it to use arcade, Thanks!
