Go to Post The difference between a robotics kid and a generic nerd. Both use their calculators for statistical analysis. One keeps it a closely guarded secret, the other brags about it on Chief Delphi! - Kevin Leonard [more]
Unread 03-02-2011, 21:20
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
In the description of the download it doesn't mention the actual cRIO image v27 itself. Do you know where that is?
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 03-02-2011, 21:54
Re: C++ New Update: V27 for cRIO
It does for me...
This update contains a new cRIO image (v27). Be sure to update your cRIO with the new image before deploying any programs built with this update.
Unread 03-02-2011, 22:06
Hmmm, I didn't notice that.
Problem is I'm using java and there is nothing saying anything about the new image in the java update. I guess I will go over to the java portion and search there.
Thanks guys for the help!
2011 Pit Crew:
HYPER Alumni
Unread 03-02-2011, 22:16
It's included in the java update also.
Unread 04-02-2011, 15:53
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Description:
1. Updated to new image (v27)
2. Fixed a port allocation error in Counter class
3. Added support for using an Encoder object as a PIDSource to a PIDController. Select either Distance or Rate as the source parameter.
4. Added SPI Class developed by Peter Johnson.
5. Implemented ADXL345_SPI Accelerometer.
6. Improved doxygen comments in various places.
7. Added the DoubleSolenoid class for directly supporting double action solenoid devices.
8. Prevent the CANJaguar class from crashing based on a NULL MotorSafetyHelper being dereferenced in the case of an error on construction.
+1 for a DoubleSolenoid class, make sure to implement this!
Unread 04-02-2011, 19:30
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
This is my 5th year to participate in FIRST. Every year I marvel how so many updates (software, firmware, rules) occur during the short six week build period. It's week 4 of the build season. What does that mean? Firmware updates! Hurray!
I can imagine the verbal exchange during one of the other 46 weeks in the year.
- Okay, the software and firmware changes are ready to go. I guess I'll make them available for download.
- Hold on there fella. That's crazy talk! If you do that now, what are we going to do during build season?
Unread 05-02-2011, 11:38
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
We are also not seeing the CRio image in the Java distribution (FRCNetbeansDist 4.12.zip).
Unread 05-02-2011, 11:48
Did you install the update? It's not in the zip file directly, it's hidden inside one of the .nbm files and will be available after you install the update.
Unread 05-02-2011, 11:54
MikeE's Avatar
no team (Volunteer)
Yes.
We installed all of the nbm files directly via the plugin manager since we don't have network access at school on our development laptop.
There is no sign of the FRC_2011_v27.zip file anywhere on the file system and the cRIO imaging tool still refers to FRC_2011_v25.zip.
Unread 05-02-2011, 12:45
MikeE's Avatar
no team (Volunteer)
Yes.
No.
The update is only applied properly during a clean restart of NetBeans, and we had failed to do that properly.
Moral: Make sure you "install" the plugins then close down and restart NetBeans.
Unread 05-02-2011, 13:16
idunno42's Avatar
idunno42 idunno42 is offline
FRC #0069
idunno42 is an unknown quantity at this point
After you install the plugins, you should able to search your computer for FRC_2011_v27. Hook up your robot to to the cRIO image tool and and then should FRC_2011_v27 listed. Chose and download.
Unread 05-02-2011, 13:33
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
We figured it out ya if you are connected to the repository then it updates both the code and the cRio image. The v27 update should be installed here: c:\Users\user\sunspotfrcsdk\cRIO_Images
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Unread 08-02-2011, 02:57
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
+Joe likes this.
