Go to Post Your drivetrain is THE most important system on your robot. Don't rob from it. - Monochron [more]
Unread 03-02-2011, 22:20
Rookie.i.am Rookie.i.am is offline
FRC Mentor - US First Team 3483
AKA: Mike
FRC #3483 (Cold Smoke)
Rookie.i.am is an unknown quantity at this point
Axis Camera on cRIO port 2 vs. DLink Access Point
Hi,
I have our Axis Camera plugged into the Dlink Access Point and I'm able to see the camera image on the Classmate Dashboard.
However, when I plug the camera into port 2 on the cRIO, I lose the video on the Classmate Dashboard.
What do I need to change in the LabView code in order to make port 2 accept the Axis Camera signal and pass it on to the Classmate Dashboard?
Thanks in advance.
Kind regards,
Mike
Unread 03-02-2011, 22:28
Re: Axis Camera on cRIO port 2 vs. DLink Access Point
The camera needs it's default IP address of 192.168.0.90 when connected to the cRIO port 2.
The camera needs a 10.xx.yy.3 or similar IP address when on the 10. network through the DLink.
Unread 04-02-2011, 08:32
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
We're working on a tutorial about this: plugging the camera into the cRIO versus the Dlink. Look for it next week on the ni.com at http://decibel.ni.com/content/docs/DOC-8923
Doug Norman
