Re: Two cypresses?
The operator controls for this years game easily exceed
8 digital inputs. If you have a 1 of N selection, you can do this with a pot on an analog input. You can emulate the same thing with switches and resistors. As an alternative to another Cypress board, you could use the hardware from a USB game stick. eStop Robotics had one, the CCI, but it is already out of stock. This is not a surprise as more than 8 digital inputs will likely be common this year. If you get another logitech joystick you will find that the actual USB interface is a small card that you can carefully extract, reverse engineer the wiring for and use for 11 more digital inputs, 9 of which will be accessible by splicing the fine wires, and the the last two by removing and soldering wires for two surface mount switches. The Cypress card/driver does have its gremlins, but it does not appear that the joystick driver shares them. Eugene Last edited by eugenebrooks : 04-02-2011 at 01:46. |
